Old 05-17-2016, 12:04 AM   #1
Mrturner1
Starter bolt stripped out, now what?
Well I found the squeaking ticking noise finally, member trac209 suggested checking the starter and although the starter is working fine, one of the bolts doesn't even tighten down. The actual engine block looks like somebody dropped it while either removing or replacing it and the starter just broke off and they welded the peice back on the block. I recently had the engine out and noticed this weld job but I just figured it was fine.
Can I get a really small and lightweight starter that would hold in fine with one bolt? Any other ideas on fixing this?
Mrturner1 is offline   Reply With Quote
Old 05-17-2016, 12:13 AM   #2
69chevytrucker
69chevytrucker's Avatar
Re: Starter bolt stripped out, now what?
devcon epoxy and fill it then drill and tap it
69chevytrucker is offline   Reply With Quote
Old 05-17-2016, 12:44 AM   #3
In The Ten Ring
We need pics!
In The Ten Ring is offline   Reply With Quote
Old 05-17-2016, 12:55 AM   #4
Chknlyps2
https://www.youtube.com/watch?v=RFYa6sjhh_E
Drill, tap and install a Helicoil, This kit is metric but you see what comes in a small kit. Amazon.com: Helicoil 5546-6 M6 x 1 Metric Coarse... Amazon.com: Helicoil 5546-6 M6 x 1 Metric Coarse...
Chknlyps2 is offline   Reply With Quote
Old 05-17-2016, 02:22 AM   #5
midniteblues
midniteblues's Avatar
starters had a few differnt bolt patterns over the years.
some blocks were drilled for both staggered and straight pattern starters.
if your block is damaged on the outer bolt hole then i wish you good luck.
if its a inner bolt hole then check your block real good you just might have another bolt hole or you could add one....if not then your choice is either too drill and tap to a larger bolt? or heli coil it....thats if the weld holds up.
drilling and tapping a block really isnt that hard. but drilling and tapping threw the weld will be harder.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-17-2016, 03:13 PM   #6
Mrturner1
Originally Posted by In The Ten Ring View Post
We need pics!
Sorry about that lol
Old 05-17-2016, 03:19 PM   #7
Mrturner1
Block is orange, you can see the weld job from this angle
Old 05-17-2016, 08:11 PM   #8
Grumpy old man
Grumpy old man's Avatar
Wow , that's one ugly weld . Drill it -tap and heli coil it ,but I'd be willing to bet it will snap off before it's done .looks like it was welded with a 110 80 amp flux core welder
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 05-17-2016, 08:42 PM   #9
Mrturner1
This is the same block that has that crack repair job you saw on my build thread....it's seen its last year that's for sure
Old 05-17-2016, 08:50 PM   #10
wahl4m
if you do get it tapped /so the bolt tightens up ???? try to put a front brace on the starter ! it might stiffen things up ?? good luck ! mike
wahl4m is offline   Reply With Quote
Old 05-18-2016, 08:38 AM   #11
Jason Banks
Jason Banks's Avatar
I had a 350 that did that. Part of the block broke off. Had a guy come out and weld in a bunch of new material. Drilled, tapped, used front brace on starter.....a couple thousand miles later the bottom end went out in the engine and I replaced it. Seemed to work fine while I had it.
Jason Banks is offline   Reply With Quote
Old 05-18-2016, 09:11 AM   #12
Rich69shortfleet
I agree, helicoil is your friend. A front strap is a requirement at all times.
Rich69shortfleet is offline   Reply With Quote
Thread Tools
Display Modes
