Old 05-18-2016, 12:32 AM   #1
ck5566
700R4 ??'s
Here & other forums (ops did I say that) LOL. I have read about installing a switch to lock up the trq. conv. Here is what I don't understand what is the purpose of locking it in/up? In stock situation doesn't it lock up in 4th gear by default? Whats the advantage of it? **My trans by its #'s is a 1992 yr.** This pic shows a Red circle in a spot that looks like some kind of electronic hookup of some sort. Is that when in its stock original fitment has something to do with the locking of the trq. conv. through the cars system? I know its a lot of ????'s. Any help is appreciated.
Danny D
ck5566 is offline   Reply With Quote
Old 05-18-2016, 01:07 AM   #2
Mrturner1
Re: 700R4 ??'s
That's not a red circle, it's a wire looped and zip tied
Mrturner1 is offline   Reply With Quote
Old 05-18-2016, 01:50 AM   #3
Rod Run
Rod Run's Avatar
Re: 700R4 ??'s
When it locks up you get better gas mileage
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 05-18-2016, 01:54 AM   #4
ck5566
Re: 700R4 ??'s
Weather it is wire looped it still is a RED Circle, That was not the Technical answer I was looking for. Any body else have a better answer?
Old 05-18-2016, 02:22 AM   #5
ck5566
Re: 700R4 ??'s
Since it is Not in its Original Vehicle and doesn't have any wires coming from the trans and going to the trucks system, with that being said it does go into 4th gear and holds there. Does those wires you know my description "Red wires" have to be hooked up some where & where?
Old 05-18-2016, 02:22 AM   #6
wbc409
Re: 700R4 ??'s
There is always more parasitic loss in an auto transmission compared to a manual transmission. This is because a manual transmission is mechanically engaging the different gears and auto transmissions hydraulically engage the different gears. There is also loss in the torque converter, compared to the clutch of a manual transmission. The oem's looked for ways to increase fuel mileage, and one of the ways was to decrease slippage in the transmission by locking the torque converter together.
wbc409 is offline   Reply With Quote
Old 05-18-2016, 02:36 AM   #7
ck5566
Re: 700R4 ??'s
Actually it could be as many as three to four wires, two is what I see.
Old 05-18-2016, 02:39 AM   #8
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: 700R4 ??'s
Yes, to take full advantage of the 700r4 you should have a way to lock and just as importantly unlock the torque convertor. There are several companies that sell kits to ad this function to your vehicle. Here is a link for a kit built by TCI and sold via Summit Racing.
http://www.summitracing.com/parts/tci-376600/overview/
I hope this helps.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-18-2016, 02:47 AM   #9
ck5566
Re: 700R4 ??'s
Now this is going in the right directions for answers. Is the "Red circle" my description how it is hooking up to the original car/truck. What and where do those wires go to or what is on the other end of those wires a switch or what?
thanks wbc409
Old 05-18-2016, 02:52 AM   #10
ck5566
Re: 700R4 ??'s
I hope this helps.
Confused still a little, Didn't the cars trans lockup by its self by default?
Old 05-18-2016, 02:53 AM   #11
ck5566
Re: 700R4 ??'s
Thank god some ones still up
Old 05-18-2016, 03:35 AM   #12
C10_ustacould
Re: 700R4 ??'s
thanks wbc409
Correct that is where the original wiring plugged into the transmission. I think it was a 4 wire plug.
Some units locked up automatically in 4th gear but not all. I'm sure an experienced transmission guy can set it up that way if you like.
I work nights so I'm always up late.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-18-2016, 07:21 AM   #13
67 chevelle
67 chevelle's Avatar
Re: 700R4 ??'s
advantages , lowers rpms at speed ,lowers temperature , increases fuel mileage ,
there are other peramiters besides just being in fourth gear , to make it lock ,
they work fine without lockup , and many are built specificaly for that , some converters dont have the clutch
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-18-2016, 08:16 AM   #14
Bigdav160
Bigdav160's Avatar
Re: 700R4 ??'s
The main job of the lockup function is to keep the fluid from overheating while in OD. In OD, the load in the converter is increased and this energy is converted into heat. As mentioned, locking the turbine to the impeller also increases fuel economy because the energy is no longer converted to heat in the converter.
No, it doesn't lockup automatically. In a Gm transmission it is electric/hydraulically controlled.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-18-2016, 09:48 AM   #15
ck5566
Re: 700R4 ??'s
So Bigdav160; the kit (TCI) that "C10_ustacould" posted from Summit I understand works somewhat like the way it would have in its Original car/truck. I have read & seen that you can manually use a switch also to lock or unlock it, picture inserted. Which of the two ways would do the job better or easier
Old 05-18-2016, 02:57 PM   #16
Davidf
Re: 700R4 ??'s
I believe one wire is +12v and the other ground. The ground is interrupted by the brake light switch and a vacuum switch. You don't want the TC locked up during emergency stops or acceleration (low vacuum). The above diagram also incorporates a manual override switch.
Davidf is offline   Reply With Quote
Old 05-18-2016, 11:49 PM   #17
ck5566
Re: 700R4 ??'s
Now this is going in the right directions for answers. Is the "Red circle" my description, how it is hooking up to the original car/truck? What and where do those wires go to or what is on the other end of those wires a switch or what?
thanks wbc409
Still looking for how & where these wires go to or hook up to
Old 05-19-2016, 09:58 AM   #18
69_C10_project
69_C10_project's Avatar
Re: 700R4 ??'s
Does the 700r4 fit with the 97 and up Vortec 350?
69_C10_project is offline   Reply With Quote
Old 05-19-2016, 10:06 AM   #19
Bigdav160
Bigdav160's Avatar
Re: 700R4 ??'s
Yes it fits fine.
The wiring is dependent on the internal wiring (it changed depending on model year and model) and there are different ways to control the TCC externally.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 05-19-2016, 10:21 AM   #20
ck5566
Re: 700R4 ??'s
I think you needed to post your question in your own forum thread!
Old 05-19-2016, 11:08 AM   #21
bMr
Re: 700R4 ??'s
And maybe you should just call PATC, which is where you lifted the original picture from, and ask them your question. They even have a product for this very situation.
http://www.transmissioncenter.net/highperf700r4.htm
bMr is offline   Reply With Quote
Old 05-19-2016, 12:17 PM   #22
Liz
Catchy title goes here..
Liz's Avatar
Re: 700R4 ??'s
It is a discussion thread. A question was asked and answered. The person asking the question has 4 posts, and maybe did not know to do so. Reporting this for rudeness, yet replying rudely is silly. Please realize not everyone is forum savvy and we have members from tween to elderly who could use a hand and not a foot.
XIII. If you are a long time member, act like one. Lead by example and assist other newer members rather then attacking them. We look upon our veteran members to use this opportunity to teach the newer members the appropriate message board usage.
Liz is offline   Reply With Quote
Old 05-24-2016, 08:14 AM   #23
69_C10_project
Re: 700R4 ??'s
Thank you. His response was rude.
Old 05-24-2016, 09:04 AM   #24
diggerbob
diggerbob's Avatar
Re: 700R4 ??'s
Way to tell em Liz!
diggerbob is offline   Reply With Quote
Old 05-24-2016, 05:00 PM   #25
ck5566
Re: 700R4 ??'s
I was just meaning that his question about a 97 what ever it was didn't have anything to do with my 92 trans. question. I felt he was stepping on my thread asking a question that had nothing to do with the original post about a 92 700R4. Next time I'll just ask him/her to re read the usage rules.
Thread Tools
Display Modes
