Old 05-18-2016, 09:14 PM   #1
In The Ten Ring
Offset air cleaner: what color was factory?
I have an off set air cleaner set up but it needs painted. Although I think blue would be pretty, I'd like to stay factory.
What would factory color have been? Is this something that needs that high temperature engine block paint?
In The Ten Ring is offline   Reply With Quote
Old 05-19-2016, 12:07 AM   #2
swamp rat
swamp rat's Avatar
Re: Offset air cleaner: what color was factory?
Only black as far as i know, same as all the other air filters, would guess semi gloss but don't quote me on that, it won't need to be High temp.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-19-2016, 12:22 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ Agreed but I think satin black (less shiny than semigloss).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-19-2016, 10:22 AM   #4
In The Ten Ring
That's good that it doesn't have to be high temperature. I think black satin was the factory shade for all underhood components, right?
Old 05-19-2016, 05:21 PM   #5
FirstOwner69
FirstOwner69's Avatar
Not necessarily. I'd say the air cleaner, brake booster (if painted), and the brackets for engine mounted accessories (A/C, alternator, power steering, etc.) were closer to semi-gloss However, they didn't look like a heavy paint application. The core support never struck me as satin either, but that may be due to the adjacent inner fenders being closer to a semi-flat black. The brackets usually appeared to be dipped. That said, I'd feel safe doing everything except the booster and air cleaner with satin since the gloss level may vary by manufacturer.
I used to wax my air cleaner. I think there would have been a lot of residue left behind if it were satin.
FirstOwner69 is offline   Reply With Quote
Old 05-20-2016, 01:01 AM   #6
In The Ten Ring
You may be right on that...semi gloss or that high temp. paint might be easier to wipe off.
Old 05-20-2016, 01:15 AM   #7
leddzepp
Moderator
leddzepp's Avatar
I use this for all applications that call for satin black. It is extremely durable, lays down smooth, and wipes clean very easily.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-20-2016, 12:01 PM   #8
In The Ten Ring
Thanks man. I want to try that!
Old 05-28-2016, 04:10 PM   #9
In The Ten Ring
The only bad thing about my "truck work" is that I have a mix of satin and gloss painted brackets! I don't guess it really matters that much.....
Thread Tools
Display Modes
