05-28-2016, 02:05 PM | #1 |
k5 k10 dana 60 6 lug semifloat 4.10 posi wide trac
started this one for my 72 k5 but truck sold before i put it in. 72 casting dana 60 center section retubed 4" wider than stock overall to track the same as front width. has later model 4.10s with a factory posi unit. 35 spline moser axels with 1/2" studs. backing plates are not included. your stock gm truck 12 bolt backing plates and drums are a bolt on deal. pads are welded on for 73-87 now. i was going to pout in my 76 k5 plow rig but that project has taken a turn. please call me with questions if you want. i have a small fortune in this thing. looking to recoup at least $2100. thanks, glen I'm going to put it over on the 73-87 side too because it will bolt in there.
website https://www.villagegarage.com/ truck guy in the whiskey world https://www.instagram.com/c10glen/?hl=en https://www.hemmings.com/stories/car...e-perfect-day/ |
05-30-2016, 07:42 PM | #2 |
Re: k5 k10 dana 60 6 lug semifloat 4.10 posi wide trac
partial trades welcome.
06-16-2016, 06:56 PM | #3 |
ttt
06-22-2016, 09:20 PM | #4 |
you may be able to ad trailing arm mounts and run it in a 67-70 c10 6 lugger
06-25-2016, 03:13 PM | #5 |
$1800 owns it
06-26-2016, 12:49 AM | #6 |
Great price!
06-26-2016, 11:41 AM | #7 |
here is a bump and a couple questions...
how wide is it overall ? and are the axles C clip axles? any pictures of the posi?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
06-26-2016, 12:22 PM | #8 |
no c clips. ford big bearing 35 spline moser axles. the bearing cups are from moser. they are truck/impala bolt pattern for backing plates but accept ford big bearing style axles. overall width is 67". thanks for the bump. i will try to pop cover later and get a pic. its a later model factory power lock to track lock set up. i didn't want the click of another detroit lock for a street rig.
Thread Tools | |
Display Modes | |
