Old 05-28-2016, 05:31 PM   #1
aod92
aod92's Avatar
Installing seat belts....Which holes do I use?
I'm about to put seat belts in my 67 c10. I have non retractable lap belts. Behind my bench seat there are 3 holes on each side. Do I use the hole that's furthest to the door, and also the one that's furthest to the middle of the cab? Also do you guys know the bolt size?
aod92 is offline   Reply With Quote
Old 05-29-2016, 09:06 AM   #2
72farmer
Re: Installing seat belts....Which holes do I use?
I too am trying to put seat belts in my 67.I took a set out of my 72 GMC donor truck.It had 1/2" course thread bolts.After trying to run a 1/2" tap into my bolt holes and ruining one I found out they were fine threaded 7/16X20.I don't know when they changed from 7/16" to 1/2".
72farmer is offline   Reply With Quote
Thread Tools
Display Modes
