Old 05-29-2016, 02:07 AM   #1
lkfldredneck
Rear leaf spring question
So i just had about a week of running around for parts and pieces to put my leaf packs back together. Finally got them back in today and super excited about it finally doing my first add a leaf set on a completely rusted (And a couple broken leaves) spring pack. In my excitement and want to get it done, i looked at my pictures for reference and looked at it backwards. I ended up installing the springs backwards (band going towards the shackle, not front) does it completely matter? Or should i expect my Sunday to be tearing them back apart to turn them around?
lkfldredneck is offline   Reply With Quote
Old 05-29-2016, 10:20 AM   #2
65standard
65standard's Avatar
Re: Rear leaf spring question
My rear springs have clamp front and back.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 05-29-2016, 11:43 AM   #3
lkfldredneck
Hmm, i havent seen rears with 2 clamps. Unless they're aftermarket or something.
But with one im not sure if it affects the suspension being rearward instead of forward. I wouldn't see why but i dont want to screw up geometry
Old 05-29-2016, 12:59 PM   #4
RDrancher
RDrancher's Avatar
I'm pretty new to the squarebody world, so I'm not sure if the springs are equal length from the center pin to the eyes. If the measurement is the same, running the spring clamps to the rear won't throw geometry off. The main reason the clamp would be preferred forward is to control spring wrap under hard acceleration. Springs located under the axle wrap less than springs over, so if you're running a flip kit the clamp position may not make much difference in your application at all.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 05-29-2016, 01:53 PM   #5
lkfldredneck
Its a 4x4 so im not running an axle flip. and i dont want the height of a shackle flip so im not doin that either haha my wise father said the only thing it could cause is the band braking under loaded conditions, but im not going to be hauling too much with this truck i dont think. if anything the bolt will break he said so either unbolt it so it doesnt break or just leave it. i was also thinking of traction bars to help with axle wrap but the takeoff test i performed with stock leafs left me thinkin there isnt much for axle wrap haha
Old 05-29-2016, 02:09 PM   #6
mongocanfly
Post Whore
mongocanfly's Avatar
My leaf band is in the front..from what I could find its main purpose is to eliminate the leafs from fanning..it also says it helps to spread shock among more than one leaf when hitting a bump.as already said.. If its the same lenth eye to center on both ends I don't see it as a problem..except the leaves spread in the rear and compress on the front under accleration..could you just move the band to the other end of the springs without removing the springs if its the bolt style or are they riveted? Wouldn't work if riveted or the clench type..
Old 05-29-2016, 02:56 PM   #7
lkfldredneck
Its riveted, thats why its a problem haha maybe later when i have time and its not so damn hot out i might swap them around if it causes any problems
Old 05-30-2016, 09:15 AM   #8
Alex V.
Alex V.'s Avatar
My C3500's springs aren't symmetrical on each side of the axle - 26" vs. 30". But according to the specs on the website I got them from, some half tons had symmetrical springs (26"-26") and some had 26"-30"'s. I'd measure if you haven't already.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 05-30-2016, 09:23 AM   #9
mongocanfly
Post Whore
If his springs aren't symmetrical he would know it for sure when his driveshaft was to short/long by 4"....
Old 05-30-2016, 09:26 AM   #10
65standard
65standard's Avatar
Just add the front clamps.
http://www.ebay.com/itm/Leaf-Spring-...pXBOO3&vxp=mtr
Old 05-30-2016, 11:07 AM   #11
Alex V.
Alex V.'s Avatar
I figured as much, but just on the off chance that he hadn't put it back together yet or somehow got it to go in.
Alex V.
Old 05-31-2016, 10:56 PM   #12
lkfldredneck
They're the 52" springs. coulda swore i mentioned that above but i guess i didnt haha
Its all back together and the driveshaft is perfect. I might add the clamps but i wonder if not having them would help offroad since ill be taking the truck through some tricky trails.
Old 06-01-2016, 09:19 AM   #13
74CustomK20
74CustomK20's Avatar
On my stock 1 ton springs 9 leaves, plus the bottom flat one, plus the 2 overloads being a c&c, they had bands both front and back. It had no flex, AT ALL. I actually heated it up and bent em straight and it helped. Since mine will be 4x4 on some rocks I figured they were hurting my flex. Plus they have a little bounce nowm
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Thread Tools
Display Modes
