Old 06-20-2016, 02:49 PM   #1
lowandlong
Engine ID???
I pulled the numbers off my block and now I have looked on a couple web sites, the most helpful was something about NASTYz28.com
I could not find an answer there.
the two set of numbers found on the block behind my alternator are
V0820FMS ( V=flint, 0820=month and day, FMS ( this is what I cant find)
CFS103652....this number im not sure about.
any help?
lowandlong is offline   Reply With Quote
Old 06-21-2016, 10:43 AM   #2
Nontwisty396
Re: Engine ID???
On the left (driver side) rear flange of the block is a casting number.
Should be 7 digits or so.
It will give you a general idea of what you've got.
I pulled a motor out of a truck that supposedly had this "built hi perf small block".
The #s were 3970010. I took those #s off the flange and I have a 69-79 350 4-bolt, 185-370hp out of a car, truck, or corvette. I can't seem to pin it down more than that. It has a stamp above the #s that says "HECHO EN MEXICO", so I researched that being worried the block was substandard, but the info I've found says it should be fine, that GM ran plants there at the time.
This info was off a list I found on NastyZ28's site.
I printed out the list of #s but lack the tech saavy to put them online. And I'm assuming you have a small block. They have similar info on big blocks as well.
Try this: www.nastyz28.com/sbchevy/sblock.php
Hope that works! If not, if you share the block # I'll look it up on the list I printed off their site.
Nontwisty396 is offline   Reply With Quote
Old 06-21-2016, 10:47 AM   #3
lowandlong
Re: Engine ID???
the engine is still in the truck and I cant get a good look at the block casting number. the numbers I found are on the passenger side and behind the alternator.
Old 06-21-2016, 10:49 AM   #4
lowandlong
Re: Engine ID???
I have good idea that it is a 350. not sure if it is a 4 bolt main. really want to know what it came out of so I have a better idea of how and what can go into it.
Old 06-21-2016, 11:31 AM   #5
Nontwisty396
Re: Engine ID???
I have an OLD book of Chevy numbers called 1953-1975 Chevrolet book of numbers, which helps identify components your motor came with and what it's out of, but again, I lack the tech saavy to share it here. (I can't even figure out how to shrink pictures to put on here!)
When I Google the book title I find it for sale on ebay and amazon. It's got a blue cover.
I haven't been able to find a way to decode the numbers stamped on the front flange of the block by the alternator.
If anyone out there has this info and will share it would be a great help! Thanks!
Old 06-21-2016, 11:50 AM   #6
GRX
GRX's Avatar
Re: Engine ID???
Despite ideas to the contrary, no way to be certain your block is 4-bolt without pulling the pan & actually looking. No biggie either way since stock 4-bolt is no better then two.
Casting numbers off the block & heads is your best bet. The front stampings are good for telling where the vehicle was assembled and what not. In the end a 1975 block is a 1975 block. The rest are add on parts. Which could very well have been changed over the years.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-21-2016, 11:54 AM   #7
lowandlong
Re: Engine ID???
thanks for all the input. the help is appreciated.
Old 06-21-2016, 12:02 PM   #8
Nontwisty396
Re: Engine ID???
I have to agree.
The motor I have turns out to be a 4-bolt 350, just like the casting #s showed. On my motor the stamp is MKO3800, which I haven't been able to trace.
The casting #s seem to be the most accurate way to identify the block, heads, crank, etc.
Old 06-21-2016, 12:34 PM   #9
Nontwisty396
Re: Engine ID???
I looked at http://www.chevellestuff.net/qd/engi...mp_numbers.htm and found a little more info, but probably no more than you already had.
If I hear back from my farmer buddy I'll pass any new info on from him.
Old 06-21-2016, 12:35 PM   #10
lowandlong
Re: Engine ID???
thanks for all your help, and time.
Old 06-21-2016, 12:43 PM   #11
lowandlong
Re: Engine ID???
that is a very helpful site. cant find my numbers but still helpful.
Old 06-21-2016, 01:14 PM   #12
hatzie
Moderator
hatzie's Avatar
Re: Engine ID???
Engine assembly code V0820FMS
V = Flint engine line
0820 = Aug 20
FMS = 1985 350 from a 3/4 or 1 TON Truck ,160hp ,LT9 RPO code ,4-Barrel
Partial VIN...
CFS103652
C = Chevrolet Truck
F = 1985
S = St.Louis assembly plant
103652 = plant sequence number
Taking a whack at the whole VIN of your donor is pretty easy with a 1985 VIN card and the engine numbers... https://service.gm.com/dealerworld/v.../vincard85.pdf
Known US-1, Chevrolet Truck-C, LT9-M, 1985-F, St Louis-S, 103652-103652
1GC????M?FS103652 (this is what the partial VIN and the engine code give us) If those match your VIN then it's a "Numbers Matching engine".
Just for fun. If I guess 3/4 ton=2, a common 3/4 ton Brake GVW of 8600 = G, 4x4 or 2wd (K or C), body type likely std 2 door cab = 4, and the check digit use the same number as the VIN card example = 3.
2wd 8600GVW Std cab = 1GCGC24M3FS106352
4wd 8600GVW Std cab = 1GCGK24M3FS106352
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Thread Tools
Display Modes
