Old 06-29-2016, 10:13 AM   #1
barry1982
1982 Door Adjustment
Hi Guys,
Well, attempted to install the drivers door on my project 82 last night. Im using a good door off of a different truck. I installed the bolts insuring they were in the same location as originals (could tell by paint around washers). My new door is way out. Seems to be too close to back of cab , and "sagging" at rear bottom. I'm thinking I have to loosen/ adjust hinge mounts on cab to correct. (have also installed new pins/bushings) The top hinge as a bolt that comes from the inside. Can I loosen the nut on hinge, or is it spot welded?
barry1982 is offline   Reply With Quote
Old 06-29-2016, 11:28 AM   #2
Gmc.guy
Gmc.guy's Avatar
Re: 1982 Door Adjustment
You can loosen the bolt from the inside. It's in a tough spot on the driver side. Don't pull your socket off Haha. There's a hole you can put a socket thru. I always leave that one loose until everything is adjusted tightened and in the final place you want then tighten it up.
-Cody
Gmc.guy is offline   Reply With Quote
Old 06-29-2016, 06:34 PM   #3
barry1982
Hmmm.... thanks GMC Guy..... I was afraid of that. Oh well, if someone put the bolt in, I should be able to loosen it.....
Old 06-30-2016, 12:17 AM   #4
Gmc.guy
Gmc.guy's Avatar
Ya. I have donated a couple 9/16 into the a-pillar on a couple trucks. Catches the lip and pops off your extension. Haha.
-Cody
Thread Tools
Display Modes
