06-29-2016, 12:34 PM | #1 |
Wiring Questions???
im redoing the gauges in my 85 c10 and im going with autometer and i wanna know when the gauge says "to ignition switch" what wire exactly do i take these gauges to, cause im confused on what wire these things have to run too, the pic is just an example? i take it that all these gauges go to the same wire?
thanks |
06-29-2016, 12:50 PM | #2 |
Re: Wiring Questions???
I / + usually means a "Switched 12 volt power source" like your ignition switch.
It provides power to the gauge when the switch is turned to the ON position only.... the ground wires can all be looped together and take one ground wire to the frame or battery (-) terminal
My Build: 57 Chevy Pro-Street |
06-29-2016, 12:55 PM | #3 |
what wire is the igntion switch wire that i wire it to in my truck?
06-29-2016, 03:02 PM | #4 |
Typically, GM used pink w/blk wires as switched ignition source. On your fuse panel there are a few spots labeled as "IGN" that you can also route wires to.
06-30-2016, 08:22 AM | #5 |
06-30-2016, 12:40 PM | #6 |
Yes u can!
06-30-2016, 02:33 PM | #7 |
Moderator
Why would you run a wire down to the fuse panel? No need to run a bunch of extra wire.
There are usually two or three grounds and two or more ignition power wires on the instrument cluster plug. Ignition power is usually pink/black and the grounds are black. Cluster illumination is usually gray. The wire colors and instrument panel plug pinout is in the factory wiring diagrams.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-30-2016 at 11:25 PM. |
Thread Tools | |
Display Modes | |
