Old 07-10-2016, 11:53 AM   #1
Motasupra
Question Seam sealer or bonding?
I'm wondering what will be best for the two spots I found on the 1953 cab we are working on?
Top of the cab has small hole in the rain gutter .
[IMG][/IMG]
The cab under the window looks like it could let water seep in but not badly rusted no pitting or blisters yet.
[IMG][/IMG]
Motasupra is offline   Reply With Quote
Old 07-10-2016, 05:00 PM   #2
Foot Stomper
Foot Stomper's Avatar
Re: Seam sealer or bonding?
First you'll need to remove all paint and rust from the afflicted areas.
Then you (and us) will have a definite solution.
Welding or seam sealer solutions will require that you take this prep step regardless.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 07-11-2016, 05:59 AM   #3
hogfarm
not being a body guy,from what I see rust is not to bad.I have used POR-15 as a seam sealer,I used it on the inside,it is not made to be used on areas that need to be smooth,when it gets hard it is very difficult to sand.but the rust needs to be addressed,I would weld rain gutters
hogfarm is offline   Reply With Quote
Old 07-11-2016, 03:04 PM   #4
my56chevytruck
my56chevytruck's Avatar
fortunately or otherwise, I've used both. Bondo is best for forming or making a better shape, so you can use that as well. but if you have a hole, I'd suggest sanding down, weld in the hole, then sand/grind down. then use your bondo to form the body back to the shape you want sand and paint. depending upon how bad the underside is, sand it, bondo, form, sand and paint. my thoughts.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 07-11-2016, 06:39 PM   #5
MARTINSR
MARTINSR's Avatar
Sand blast, then epoxy primer then 2k seam sealer is how I would do it. As far as the hole, if it's down in the gutter at the bottom, it is likely fine to be left there and then seam sealed after sand blasting and epoxy primer. It really depends on your skills and the access to the hole. If you can weld it up then of course that's the best way. Then of course you want to do the same thing inside with epoxy primer. If you can't spray it in there you could brush it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-11-2016, 11:39 PM   #6
Motasupra
Thanks for the info so everyone. . Wire wheel to kick out the rest of what in the crease??
Not much rust in there but lines of separated sealer is what it looks like. The truck is root beer brown and looks like all rust in the pics. There's rust for sure though. I have about no body work knowledge. But I got a book and some tools. An old set of Grandpa's body hammers and time. Ha ha ha
Old 07-11-2016, 11:41 PM   #7
Softpatch
Softpatch's Avatar
seam sealer for the win.
(Dynatron 550 Auto Seam Sealer)
you get a 15min work time.... 4-6 days to totally set and its paintable
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 07-12-2016, 05:39 AM   #8
MiraclePieCo
MiraclePieCo's Avatar
Seam sealer is so easy to use, and you can wipe it out and try again if you don't get it perfect the first time. Paintable, flexible and lasts the life of the car, it's really hard to beat for filling stuff like that.
MiraclePieCo is offline   Reply With Quote
Old 07-12-2016, 09:42 PM   #9
Motasupra
Wire wheeling all day. It doesn't look that bad. It's bondo in the crack and some surface rust I think.
[IMG][/IMG]
Old 07-12-2016, 09:49 PM   #10
Motasupra
This is the top of the cab. It looks like a drain to me but I don't know why there would be one there. It would be hard to weld it in the little space but I may try it.
[IMG][/IMG]
Old 07-17-2016, 05:07 PM   #11
Softpatch
Softpatch's Avatar
Unlike bondo which will hold moister
seam sealer is more of a sealer and is workable like bondo but once set you cant really sand it
pread it on smooth it out let it set and move on
and when dries it has minimal flex and can be painted
it's really wonderful stuff
it's like a 20yr durability.
that's way longer then I'll be around
well maybe not in Arizona but real word application
Thread Tools
Display Modes
