Old 03-30-2002, 12:16 AM   #1
big.l.a
big.l.a's Avatar
Talking HEI Diagram of Plug wire location
Does anyone have a diagram as to the location of the #1 plug on a HEI setup
I am converting from points setup.
71 C10 LWB
79 Monte C
71 C10 LWB With
Edelbrock 7101& 1406 Carb
Accel HEI Blue Print
Accel 8.8 Wires
Soon to have possi &
186 Camel hump heads
Dropped 2-1/2F&4R
Dynomax Headers
Duals Flowtech Aftburners
Tonneau Cover Frm 89 F150
79 Monte C
big.l.a is offline   Reply With Quote
Old 03-30-2002, 01:51 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
Post
I have found this to be the easiest way to set a distributor. For me anyway.
Pull the #1 plug (plug closest to the radiator on the drivers side) and bring the piston to top dead center on the compression stroke. Drop the distributor in so that when it's seated, the contact on the rotor is facing the #1 plug hole. When you set the cap on, the #1 plug wire will go where the rotor makes contact.
That's it, you should be close enough and will just need to adjust the timing by retarding or advancing the distributor. If it won't time where you dropped it in, you may need to pull the distributor back out and move it forward or backwards by 1 tooth.
Works evertime for me...........
67 SWB 4x4 - 396 BB / SM420 4 spd
8" lift / 15x14 Welds & 35X14.5 SSR's
Grants Pass, OR
[This message has been edited by Pont (edited March 30, 2002).]
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Thread Tools
Display Modes
