Old 07-12-2016, 12:23 AM   #1
fireblade_rr
Edelbrock 1406 carb
Please see pics, problem was much worst and this is the result after the below was performed.
Carb completely rebuilt, float height set correctly per edelbrock specs.
Installed a fuel regulator set at 4.5 lbs, have tired 5.5 and 5 lbs
Timing is set
Carb adjusted with vacuum gauge
Why and or where is this fuel coming from?
Driving me nuts and want it fixed until the pull the trigger on EFI
Thanks!
fireblade_rr is offline   Reply With Quote
Old 07-12-2016, 01:23 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Edelbrock 1406 carb
I suspect that you have a float issue or some other internal leak that causes the gas to run out of the throttle shafts
dwcsr is offline   Reply With Quote
Old 07-12-2016, 02:03 AM   #3
Coupeguy2001
Coupeguy2001's Avatar
It is possible on a tandem float if one float is cracked and absorbing fuel, it would float partway up when the bowl is full, you are getting the bowl overflowing .
Coupeguy2001 is offline   Reply With Quote
Old 07-12-2016, 02:10 AM   #4
tmoble
yeah, throttle shafts don't contain fuel and don't leak. What's happening is the floats are not properly controlling the fuel level or the carb is boiling over. fuel drips from the booster ventruiis onto the butterflies and runs out the ends of the shaft. It can do this from either side or both. get it good and warmed up, pull the air filter and look down into the carb with good light. You should be able see dripping.
99% of these problems are caused by tiny specks of dirt in the needle and seat. where is your fuel filter and what type is it?
tmoble is offline   Reply With Quote
Old 07-12-2016, 03:27 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by tmoble View Post
yeah, throttle shafts don't contain fuel and don't leak. What's happening is the floats are not properly controlling the fuel level or the carb is boiling over. fuel drips from the booster ventruiis onto the butterflies and runs out the ends of the shaft. It can do this from either side or both. .
I'm confused by your answer . first you say they don't leak and then you say gas runs out the end of the shaft????? So can gas leak from a shaft or not leak?
Old 07-12-2016, 05:31 AM   #6
MiraclePieCo
MiraclePieCo's Avatar
A couple of ideas:
1) It's not gas, it's oil wicking up the intake bolt threads. Put thread sealer on them.
2) You need a vented fuel cap. Since it's summer, your gas is heating and expanding, pressurizing your entire fuel system and blowing gas past the needle/seat and overflowing the fuel bowl. Had it happen.
MiraclePieCo is offline   Reply With Quote
Old 07-12-2016, 08:35 PM   #7
crossfire84
crossfire84's Avatar
are you sure its an edelbrock and not a weber carb?
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 07-12-2016, 09:44 PM   #8
mr48chev
mr48chev's Avatar
Tmoble gave just about the same concept of what I thought might be happening.
No there shouldn't be gas on the throttle shafts working thorough the bores in the base plate but if there is excess gas leaking inside the throttle bores and hitting the throttle plates it can work it's way out alongside the shafts especially if the shafts and bores of the shaft holes are worn.
Dirt under the seat, faulty float or gas being pushed through the line to the carb due to a tank that isn't vented properly.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 07-13-2016, 09:23 AM   #9
Coach529
Coach529's Avatar
My Edelbrock 1406 has the same Weber stamping.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-13-2016, 02:44 PM   #10
mr48chev
mr48chev's Avatar
Now I'll have to go look at mine tonight to see what's on the side. No matter they are all clones of the old Carter AFB
Thread Tools
Display Modes
