07-20-2016, 10:11 PM | #1 |
c-4suspension on AD truck?
Will 1985 corvette suspension work on a 54gmc or is to wide? Im trying to make a plan for a original frame,one option is c-4,i see guys using c-4 on task force trucks,anyone use it on ADtrucks.thanks mike
07-20-2016, 10:36 PM | #2 |
Post Whore
Re: c-4suspension on AD truck?
Oh yes...its nearly a perfect fit for the ad trucks..an 85 vett is about 59 1/2" wide..check out flatout engineerings crossmembers..I have one going in and there are several more builds both ad and tf going on now on here
07-21-2016, 12:42 AM | #3 |
There are a good number of trucks around running the Flatout Engineering setup. I think there is at least one in the build section with C-4 suspension too.
One thread here with a couple of photos from a couple of years ago. http://67-72chevytrucks.com/vboard/showthread.php?t=
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 07-21-2016 at 12:49 AM. |
07-21-2016, 08:53 AM | #4 |
Thanks,I should of done a little more reading.I saw a few builds on TFtrucks,just missed any early truck suspension builds.Flatout eng.crossmember for frontend and stock c-4 IRS for rear, just kicking around different options,Mike
07-21-2016, 01:41 PM | #5 |
I had to go a few pages to find that one. There are a lot of build threads when you start counting and scrolling down though them.
07-21-2016, 02:37 PM | #6 |
Post Whore
There are a few others manufactures of the vett crossmember but I chose the flatout based on reviews I read..there are even some drawings on here where you can build your own copycat from a flatout crossmember..I started to build my own but wanted to make sure I didn't screw up the suspension geometry so I went ahead and splurged..but what I am doing is building me a jig from this crossmember so if me or my buddys want one we can fab up the parts and build one in the jig in the future..I also looked at the Dakota crossmember but trying to chase down all those parts was going to be a hassle..darn scrap prices and cash for clunkers have wiped out all the good junk yards that had all the good older stuff...now all, you can find is less than 10 -15 yr old stuff..
07-21-2016, 02:38 PM | #7 |
Post Whore
Mr48 I couldn't get that thread to work..
07-21-2016, 02:51 PM | #8 |
Post Whore
One suprising bonus about the vett front end is the weight..just like you see my donor sitting on the sawhorse( hub to hub with rack, spring and everything you see in this pic) it weighs 143lbs..that will change up or down some when I move the components over to the flatout and ad the coilovers. (mines a 88)
07-21-2016, 10:09 PM | #9 |
I'd ask what a C4 weighs versus what a 54 truck weighs before asking about width. Parts are engineered for the stresses of the vehicle.
07-21-2016, 10:53 PM | #10 |
I used the Flat Out front and rear on my 57 3100. I read somewhere (classic trucks, I think) that the C-4 weighs 3200 lbs. About the same as a 6 cylinder version of my truck.
07-22-2016, 11:49 PM | #11 |
I installed one on my 47 a few years ago. At the time the instructions were had written and inaccurate. The front kit is probably worth the money. Build your own rear if you can. It is just a few brackets and a few straight pieces of tube. I had done another brand of Mustang II on a 40 ford I had and it was a much better kit with instructions than the Flat-out kit. Be careful about the wheel base. You will probably want to move the front forward and the rear back. The front moves easily but the rear kit does not move back without redoing the entire setup. At the time I did mine the support was terrible. It took weeks to get a call back to answer questions. I think there are only two guys there.
07-23-2016, 07:54 AM | #12 |
Build your own for the rear, very easy to do check out my build thread, good luck.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
07-23-2016, 03:33 PM | #13 |
Thanks for the advice on building the rear brackets myself, I just bought this 85 corvette but not sure I want to start parting it out,The crossfire engine and automatic tranny are good so i might use that stuff also? I will keep reading other guy builds and go from there.Thanks again,Mike.
07-25-2016, 09:58 PM | #14 |
DO IT!!! I also built my own rear brackets. Hardest part is figuring out the geometry.
07-26-2016, 02:19 AM | #15 |
I was on the way to work yesterday morning and next to the place I have breakfast a lot of mornings was this = (not sure where the two photos are going to go.
Guy had a half a Corvette with what appears to be a complete front suspension and not much more. Next door to Major's hamburgers on 3rd and Washington in Yakima if any0ne headed to Vintiques this weekend is interested. I see cars and parts all over set out in hope of one of those "hot rod guys at Vintiques" has deep pockets.
07-26-2016, 08:24 AM | #16 |
Post Whore
Did it have a price on it mr48? Wrong end of the country for me..
07-26-2016, 07:06 PM | #17 |
07-29-2016, 10:44 AM | #18 |
Pictures of my truck and current ride height.
07-29-2016, 11:23 AM | #19 |
Oooohhh, I like Black G M C's !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-29-2016, 02:10 PM | #20 |
Post Whore
I agree with solid..that looks nice..real nice..like the grill..black outer w/chrome inner..
Thread Tools | |
Display Modes | |
