07-26-2016, 07:57 PM | #1 |
1 ton wheels
Good evening Gents
Can I put 1ton wheels on my stock c20 ? |
07-26-2016, 08:08 PM | #2 |
Re: 1 ton wheels
As long as they are the older lug pattern of 8x6.5 not the newer metric pattern. Also Check to make sure the hub hole is big enough to clear your axles. If they're newer wheels watch the off set too. When my truck was still 8 lug I put a set of steel wheels for a mid nineties Chevy on it.
It only has original paint once |
07-26-2016, 08:31 PM | #3 |
Re: 1 ton wheels
I didn't give enough info. I have as 66 c20 with farm dump bed. It has 265/75 r16 on modern rims on it now. I need new tires. I found 6 ford wheels with 9.5r16.5 almost new tires for 500 bucks. Thought the duals might help. I haul 2 tons sometimes. New lugs and studs? Just pondering. Thanks ,Lowell
07-26-2016, 08:59 PM | #4 |
Check The Champ, Demonstrator
Re: 1 ton wheels
The Ford wheels could have a larger centerbore, therefore you'll be placing all the weight on the studs.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
07-26-2016, 11:04 PM | #5 | |
Re: 1 ton wheels
That's a great point. The centerbore on my F350 Wheels are larger then my Chevy Wheels.
07-26-2016, 11:24 PM | #6 |
Re: 1 ton wheels
The dual type wheels might bolt up BUT on the front IF you can get them on i doubt you will be-able to turn the wheel (left/right)..... ON the rear they will most likely hit the springs (if leaf) or trailing arms... A lot of differences on a cab and chassis dual wheel truck AND even MORE on a pick up bed dually axle length , WMS to WMS , spring with ECT. ECT.
07-26-2016, 11:54 PM | #7 |
Re: 1 ton wheels
Most of the time the C20 brakes are larger in diameter than C30 brakes, which are smaller & wider than C20 brakes. At least on the ones I have worked on. So the inner wheel won't fit over them. I have also found the C30 brakes to be mounted farther inboard also & in my ambitious early years actually moved a set inboard to make the rims fit, but NEVER again! I have seen folks use spacers but use at your own risk!
07-27-2016, 02:05 AM | #8 |
Re: 1 ton wheels
poor old worn out trucks getting that kind of abuse.
ron |
07-27-2016, 06:58 AM | #9 |
Re: 1 ton wheels
I don't know about 66, but in 63 you could get a C20 with dual rears on trailing arms and coils.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 07-27-2016 at 07:17 AM. |
07-27-2016, 08:47 PM | #10 |
Re: 1 ton wheels
Thanks very much to all of you ! Looks like I best just get new tires. Have a great evening.
Thread Tools | |
Display Modes | |
