07-27-2016, 07:27 AM | #1 |
NP205 paint
I was paging thru the np205 rebuild thread at the top of the forum, and it looked like the inside of the case was painted. Was this intentional, or just a messy painter at the factory.
If it was intentional, what kind of paint would hold up to constant hot oil immersion? Im rebuilding a 205/th400.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
07-27-2016, 11:44 AM | #2 |
Re: NP205 paint
Did a little more surfing and it looks like Glyptal, Armature paint, electric motor paint all would do the job.
But that still leaves the question... is it painted inside intentionally ?
07-27-2016, 12:52 PM | #3 |
Re: NP205 paint
This is what I use. It helps oil drain back and fills rough and uneven surfaces without cracking and chipping.
http://search.eastwood.com/search?w=Glyptol Engine enamels should work as well for a little cheaper. I've used them in the past without any real issues to report. I think they can flake easier tho without a real good surface prep. Surface prep being a darn good washing and zero oil residue. Leave the casting rough for bite. Some like to polish the surface smooth which does not help the "bite" for the paint. Also, brush on only, toss the aerosol can. Where's the link to your build? It's been a while since I visited it. I remember you have an enjoyable build. Steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
07-27-2016, 01:28 PM | #4 | |
Re: NP205 paint
I saw Eastwood has the Glyptol and that is with in driving distance to me.
07-27-2016, 01:50 PM | #5 |
Re: NP205 paint
eh, maybe it wasn't a build thread rather just some odds and ends works I had read through the years. memory escapes me.
ya, the Glyptol is a little pricey but works well.
07-27-2016, 02:13 PM | #6 |
Re: NP205 paint
Here's one... http://67-72chevytrucks.com/vboard/s...ighlight=miler
07-28-2016, 08:07 PM | #7 |
Re: NP205 paint
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
07-29-2016, 07:46 AM | #8 | |
Re: NP205 paint
Why paint it? Why not paint it? Or why in the road? I want to know if GM painted them intentionally... or sloppy employee with a spray gun. I dont think quick oil return was the idea for painting them. Maybe keep sand and loose cast iron in place. Or maybe it was to keep the inside of the case from rusting in case of water infiltration. Or .....maybe....the foreman's son with no skills needed a job.
07-29-2016, 05:02 PM | #9 |
Re: NP205 paint
Well I thought the link was self explanatory, meaning no they weren't painted intentionally and why choose to paint the inside anyway.
07-29-2016, 07:58 PM | #10 |
Re: NP205 paint
There is a good reason for Glyptol, to aide oil in draining back to bottom to be picked up again, rather than slowly because of rough cast surface. It's up to you if it's worth the bother. I don't think GM went to the expense for us. It's an over and above improvement that many, including gm bean counters, will say is not worth the bother. I say, if it's torn down and cleaned up, why not?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-30-2016 at 07:42 AM. |
07-30-2016, 06:54 AM | #11 |
Re: NP205 paint
When nascar told smokey yunick he couldn't port and polish the heads he used that Glyptol paint and it worked.
07-30-2016, 07:24 PM | #12 |
Re: NP205 paint
Wow, Smokey Yunick painted Glyptol in his 205? My God no wonder he was so F'n fast....
07-31-2016, 08:39 AM | #13 |
Re: NP205 paint
I'm not in the race, so I ported and polished my transfer case. Glyptol is for sissies!
07-31-2016, 11:19 AM | #14 | |
Re: NP205 paint
Thread Tools | |
Display Modes | |
