Old 10-04-2003, 11:45 PM   #1
messed up c-10
RHCP afficianado
messed up c-10's Avatar
electric problems
Ok. I thought I could fix this on my own but I'm runing into some problems. A couple of days ago I tried putting a dome light into my truck. I used the wrong kind by mistake. My dome light uses to prongs and I used a light that has one prong. When I stuck it in my light under the dash kind of flickered and went out and my radio went off. I took the light out and my lower light came back on but my radio and in-dash clock didn't. The radio lights up but it wont come on. I looked through the fuse box and I can't find any burned out fuses. I'll be heading out there in the morning to go back to work so any help you guys can give would be great.
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 10-05-2003, 02:18 AM   #2
Russell
Professional Grade
Russell's Avatar
Sounds like you might have fried your radio... Is your dash clock a digital clock? If so, you may have fried it too...
I've had the same thing happen before, lots of lights, but no noise, had to get a new radio
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-05-2003, 02:29 AM   #3
messed up c-10
RHCP afficianado
my dash clock is analog. Oh well. If I did fry it then I guess that will make me install that new one I got instead of putting it off.
~Ryan~
Jack Johnson
Old 10-05-2003, 02:32 AM   #4
Russell
Professional Grade
Russell's Avatar
Hmm... thats odd, your clock shouldn't have been fried by a short... Maybe one or two wires melted together somewhere?
Old 10-05-2003, 02:39 AM   #5
messed up c-10
RHCP afficianado
I hope I don't have any melted wires. Its a pain to have to get in there behind the dash to fix things. I might pull the headliner off tommorow to check the wires to the dome light to figure out why it wont work ( it hasnt worked since I bought the truck). It did something like this before but before it just blew a fuse.
~Ryan~
Jack Johnson
Old 10-05-2003, 02:41 AM   #6
Russell
Professional Grade
Russell's Avatar
Yeah, I typically blow the fuse too...
My dome light has never worked either, nor with the light under the dash, its really dark in that truck at night, and my guages are really dim too, lol, hopefully this chrome paint will help with the guages...
How exactly does one get the headliner off without wrecking stuff? I would really like to fix my dome light too
Old 10-05-2003, 02:45 AM   #7
messed up c-10
RHCP afficianado
I just figured if you handled if carefully it shouldn't mess it up, but I could be wrong. I havn't removed a headliner before.
~Ryan~
Jack Johnson
Old 10-05-2003, 02:46 AM   #8
Russell
Professional Grade
Russell's Avatar
Any tips you have later on would be nice
Old 10-05-2003, 02:52 AM   #9
messed up c-10
RHCP afficianado
here's a pic of my newer radio that I need to install. I've been thinking of getting one of those Headliners from JC Whitney or LMC with four speakers in it and a slot for the radio.
~Ryan~
Jack Johnson
Old 10-05-2003, 04:37 AM   #10
Mike76251
You are a brave guy putting in Alpine stuff!!
I bought Alpine for quite a few years (always their best) and kept having lots of problems.
The biggest problem was always the cheap plastic gears inside coming apart and a few scrambled controller chips.
Mike76251 is offline   Reply With Quote
Old 10-05-2003, 08:11 AM   #11
stan79chevy
stan79chevy's Avatar
messed up c-10
did you pop your radio out and see if it was the fuse on the back of the radio? thats what happened to mine.
stan79chevy is offline   Reply With Quote
Old 10-05-2003, 09:43 AM   #12
messed up c-10
RHCP afficianado
The radio and cd changer only cost me $100. So if anything goes breaks I'm not out a whole lot.
~Ryan~
Jack Johnson
Old 10-05-2003, 10:46 AM   #13
79Chevypickup
MY TRUCK IS FOR SALE!!
79Chevypickup's Avatar
Re: messed up c-10
Thats what I was thinking too!!!!
1979 Chevy LWB
350ci / 700R4
Edelbrock under the hood
F O R S A L E OR T R A D E
79Chevypickup is offline   Reply With Quote
Old 10-05-2003, 11:23 AM   #14
Mike76251
I hear ya',
I bet that stuff cost $600+ new and I KNOW why it has such a low resale value.
Kinda' like when I put a cassette player on my lawnmower and someone on here asked "What? no CD player"
The cassette player was free.
Old 10-05-2003, 11:49 AM   #15
messed up c-10
RHCP afficianado
Re: messed up c-10
Do you have to open up the radio to replace the fuse because I can't find a fuse back there. I replaced the glass fuse in the little black box even though it wasnt blown and it didn't do anything.
~Ryan~
Jack Johnson
Old 10-05-2003, 12:12 PM   #16
Mike76251
Is that little black box just a fuse holder or does it look like there is more to it?
It could be a 12v to 12v converter.
Old 10-05-2003, 12:26 PM   #17
messed up c-10
RHCP afficianado
there is more to it. I'll go get a pic of it real quick.
~Ryan~
Jack Johnson
Old 10-05-2003, 12:40 PM   #18
messed up c-10
RHCP afficianado
there are two glass fuses in the box. Here is the inside.
~Ryan~
Jack Johnson
Old 10-05-2003, 12:41 PM   #19
messed up c-10
RHCP afficianado
here is the outside of the box.
~Ryan~
Jack Johnson
Old 10-05-2003, 01:22 PM   #20
Mike76251
Thats a 12v to 12v converter,
Glad you have a camera!
Check for 12v on the other side of the supply line going to it.
Old 10-05-2003, 01:49 PM   #21
Prerunner1982
Prerunner1982's Avatar
headliners are easy to get out, just pull the trim panels, above doors, and front and rear windows. it should almost just fall out. you also have to drop the dome light so it can slip through the hole. the wires for the dome light, run through the roof, NOT the headliner. so there is really no need to pull the headliner to check.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-05-2003, 05:16 PM   #22
1FaastC10
1FaastC10's Avatar
the new stuff isnt bad at all. my 3 best friends all use Alpine head units, and had Alpine amps up until a couple months ago. all 3 of them have competition quality systems. i have an Alpine CDA-9811 in my 91, and i love it.
1FaastC10 is offline   Reply With Quote
Old 10-05-2003, 05:37 PM   #23
messed up c-10
RHCP afficianado
I replaced both fuses in the 12v to 12v converter and it didn't do anything. I'm starting to wonder if I did short out my gauge clock and radio, but if I did short them out how come nothing else shorted out?
~Ryan~
Jack Johnson
Old 10-05-2003, 06:14 PM   #24
crackajacka
Stylin
crackajacka's Avatar
did u look inside the deck yet? my sony xplod has 1 fuse at the back which gets covered by the harness that plugs into the back and 2 inside one for the lights n stuff and one for the output (i think)
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 10-05-2003, 09:21 PM   #25
stan79chevy
do you have a test light
id use a test light to see if you have power to the radio. also follow the wires to see if there is an inline fuse anywhere. it takes alot to fry a radio. usually wires will melt first.
use the test light before the converter and after it may be defective
Thread Tools
Display Modes
