Old 08-13-2016, 08:40 PM   #1
chazdo2
1971 Chevy Pickup rpm problems
I have a 71 Chevy 4x4. It has the old dash. It seems like it revs too high for the speed I am going. Not sure what the gear ratio is. The dash tac has no numbers on it but appears to work. It has inside and outside hash marks on the tac. When I am going around 55 MPH it is at about 4 oclock. You guys who know these trucks inside and out have a guess at what RPM I am running at that angle? If it is too high can I change the gear ratio in the rear end?
chazdo2 is offline   Reply With Quote
Old 08-13-2016, 10:55 PM   #2
trac209
Re: 1971 Chevy Pickup rpm problems
Need to know rpms from a tach with numbers before anyone can be of any help
trac209 is offline   Reply With Quote
Old 08-13-2016, 11:18 PM   #3
firedemon
4 oclock position would be about 8000 rpm might be a bad tac or a 6 cyl tac in an 8 cyl engine or if the engine is screaming for mercy your gears could be crazy
firedemon is offline   Reply With Quote
Old 08-13-2016, 11:42 PM   #4
kwmech
Sure you're not in lo-range
kwmech is online now   Reply With Quote
Old 08-14-2016, 06:28 AM   #5
chazdo2
Its not in low the floor shifter is a bit stiff but works. Its an auto tranny and does shift. I was looking at pics of the dash board on the internet. It looks like the tac goes from 0 to 5k on all of them. So I guess I would be running around 4k. I think its a three speed auto. Maybe its not shifting into 3rd? Any suggestions here much appreciated. Kind of a newby back yard mechanic! Should add it has a 350 with a small lift and 30 inch tires.
Thread Tools
Display Modes
