Old 08-14-2016, 10:25 AM   #1
scooterpimp
scooterpimp's Avatar
71 trailing arm torque with poly bushings
I really couldn't find an answer researching site. Anyway is it ok to torque rear trailing arm pivot bolts with poly bushings without having the weight of truck on the ground like when rubber bushings are used? Being they pivit internally. ? Trying to button up rear suspension & rear is in mid rebuilding & wont be able to install for a while..thanks.
scooterpimp is offline   Reply With Quote
Old 08-14-2016, 02:00 PM   #2
Trevor
Trevor's Avatar
Re: 71 trailing arm torque with poly bushings
Yes, it's a no-no to tighten an OE-type rubber bushing in any other position than final-weight and ride-height,
but because poly bushings freely rotate around their inner sleeve (unlike the OE rubber type) you can literally torque the bolts tight in any position you want.
Trevor is offline   Reply With Quote
Old 08-14-2016, 05:06 PM   #3
scooterpimp
Cool , thanks for the reply.
Thread Tools
Display Modes
