Old 08-22-2016, 08:12 AM   #1
50dude
1950 steering box
1950 gmc everything is new in front end using original box steering seems good but when driving the steering wheel will get off from center meaning ill be going straight but steering wheel will be turned when i stop i can straighten back to center again what is causing this in box thanks
50dude is offline   Reply With Quote
Old 08-22-2016, 11:36 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1950 steering box
Is it on all roads even flat highways? Or just county or side roads?
The crest of the road will cause this, Highways don't usually have a crest for water run off like county roads or side roads. low tire pressure can cause it. Tires should be with in 2 psi or each other. The box may have some play but that usually shows up as drifting left and right.
dwcsr is offline   Reply With Quote
Old 08-22-2016, 03:53 PM   #3
mr48chev
mr48chev's Avatar
Is it trying to go to one side or the other as Dwcr is asking or is the truck going straight but the wheel is off center?
Straight smooth road hands off the wheel what does it do?
My ongoing truck projects:
Old 08-22-2016, 05:13 PM   #4
50dude
It goes straight no drifting at all just it starts out straight with the world but as i drive it gets off center but when i stop it will center again probably nothing but just seems weird
Old 08-22-2016, 11:57 PM   #5
nvrdone
have you tried adjusting the free play in the box ? should be able to take most of the looseness out & make it steer much better
nvrdone is offline   Reply With Quote
Thread Tools
Display Modes
