Old 09-04-2016, 09:30 PM   #1
Tquillen
Lord, it's yet another bench seat question...
I've read all the threads (numerous times!) regarding non-stock bench seat installation in these trucks, and my question is for the taller fellers among us.....
I'm 6'6" and around 240, and danged if this '69 cab doesn't feel small to me. It currently has the factory bench, which I will be replacing. I'm fabricating a rear mount fuel tank, and want access to the space behind the seat.
In all honesty, at this point I'm open to either a bench or bucket seats. I scored a really nice set of 2005 Silverado single cab 40/20/40 seats that were nowhere close to working, so I know that style of seat is out. Is the 88-93 bench my only option? Are there any buckets that work well for someone my height? I do want a headrest. Well, actually my wife wants headrests, and being able to see them through the back window doesn't bother me at all.
Any input from the taller guys among us?
Edit: I also tried bucket seats from a '72 Chevelle and a '74 Nova. No dice there, either.
Tquillen is offline   Reply With Quote
Old 09-04-2016, 09:53 PM   #2
custom10nut
custom10nut's Avatar
Re: Lord, it's yet another bench seat question...
I know a guy with the same issue. He has a 60/40 split seat out of an early 90s truck. He had a guy fabricate mounts that dropped the seat three inches and moved It back a little too.
custom10nut is offline   Reply With Quote
Old 09-04-2016, 11:23 PM   #3
Tquillen
That's what I'm figuring on. I've got the fabrication part covered, I just want to get the best seat I can for my situation. I wonder if the buckets out of those same year trucks have similar "clearance" as the bench?
Old 09-04-2016, 11:37 PM   #4
davischevy
davischevy's Avatar
A friend of mine just used a second row seat out of a 2007 up Tahoe/Yukon and fabricated brackets. Looks and sits great.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-04-2016, 11:44 PM   #5
Tquillen
I've heard of that being done....did he have a slider track as part of the mount? I might be able to accomplish this.....I'm 6'6", and my wife is 5'5" LOL......if it fits me well from a legroom standpoint, she may have to slide it up a click.
Old 09-05-2016, 04:01 PM   #6
ripper70
ripper70's Avatar
I Put a 98 Chevy Split bench in my build...check it out. I'm 6'1 and its fine...definitely room to lower down if need be. It sits about same height as stock.
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 09-05-2016, 04:54 PM   #7
leftybass209
leftybass209's Avatar
The c1500 bench and/or buckets have the thinnest back I've seen in these trucks. Some people may say you'll gain room when you remove the fuel tank, but that doesn't do much unless you like a 90 degree seating position, as the seat hits the rear cab wall below the window before coming in contact with the seat.
Most 2nd and 3rd row seats are equivalent in depth to the c1500 seats, but may incorporate belts, and armrests. Some also have a lot less manuverability.
leftybass209 is offline   Reply With Quote
Old 09-05-2016, 11:52 PM   #8
jcblue
jcblue's Avatar
Hey man.. Shoot me a text.. I have what your looking for. 270-779-7210. Newly redone black low back buckets and console.. I went back to a bench. Brackets cut down as well
jcblue is offline   Reply With Quote
Old 09-05-2016, 11:54 PM   #9
jcblue
jcblue's Avatar
Pic of interested.
Old 09-06-2016, 01:50 AM   #10
sigma 3
If he id not interested, whats the asking price? and why did you go back to the bench?
sigma 3 is offline   Reply With Quote
Old 09-06-2016, 08:42 AM   #11
Tquillen
Thanks for the offer, but I'm looking for something with headrests. I appreciate it, though!
Old 09-06-2016, 11:16 AM   #12
transfromer58
i would be interested in a price as well, im 6'5" and could use alittle more room as well.
transfromer58 is offline   Reply With Quote
Old 09-07-2016, 08:18 AM   #13
68Stepbed
68Stepbed's Avatar
The 88-98 bench does help. I'm 6'4" and I liked the way the 92 bench fit in mine. When I put the 72 Cheyenne seat in a few years ago, it put me higher and farther forward. It took some getting used to. I'm currently looking into a set of Corbeau racing seats since I mainly intend to do performance driving and auotcrosses in my truck. TMI Products makes a pretty slick bench with cutouts and good looking bucket seats if you're interested in that option.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-07-2016, 11:10 AM   #14
raggedjim
raggedjim's Avatar
The 88-94 bench is the most easily modified to fit. You can cut down the side brackets and weld them where you want them and a good shop can cover them to look like it came with the truck. IMHO later seats lose the vintage feel (if you are going custom it doesn't matter.)
They have a thinner back and seat foam so you may get what you want without modifying the brackets.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Thread Tools
Display Modes
