Old 09-11-2016, 09:59 AM   #1
cruisinthe34
cruisinthe34's Avatar
Rear Coil Spring problem
In the process of doing the rear 6" drop. Got the shocks off fine. I dont think the panhard bar will be a big issue. The problem is the coil springs. The spring retainers lower have rusted away. I have saturated the upper bolts with PB Blaster and still no joy. I could cut the springs out with a hot wrench, but still leaves the bolts etc. Any alternative thoughts on attacking these 45 year old rusted in bolts ??
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline   Reply With Quote
Old 09-11-2016, 11:13 AM   #2
ED67C20
Re: Rear Coil Spring problem
Maybe heat up the rusted bolts with your hot wrench. PB works good but heat seems to work every time. Be careful PB is flammable.
ED67C20 is offline   Reply With Quote
Old 09-11-2016, 11:16 AM   #3
71swb4x4
71swb4x4's Avatar
Before I read Ed's reply I thought the same thing, heat the bolts up with the torch. If they still don't come off cut them off, you can cut the spring side off once the spring is gone.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-11-2016, 11:31 AM   #4
scooterpimp
scooterpimp's Avatar
I recently went through this , was able to pull springs off rusted plates & used cutoff wheel to cut off bolt heads. Wear eye ect. Protection , sparks etc. will be a flyin.
scooterpimp is offline   Reply With Quote
Old 09-11-2016, 12:24 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Had to cut mine as well... not uncommon to have to cut them.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-11-2016, 03:41 PM   #6
cruisinthe34
The lower passenger side spring capture is completely eaten away.
Both the uppers look about the same
Steve
Old 09-11-2016, 03:43 PM   #7
cruisinthe34
May just cut the spring to get most of the out. then start with a cutoff wheel. Just ordered new spring captures today.
Steve
Old 09-17-2016, 07:28 AM   #8
cruisinthe34
Ended up cutting the coil springs (both sides), then cutting the U-Bolts front and back both sides, fighting to get the ends of the U-Bolts out of the trailing arms and reaming the trailing arms for the new U-bolts. Re-assembled everything only to learn that back in March my buddy installed the Rear Shocks on the front. Fixed that problem, and now all thats left is I need to center up the rearend.
Steve
Old 09-17-2016, 07:29 AM   #9
cruisinthe34
As a side note......Impact wrenches are a WONDERFUL thing.
Steve
Old 11-01-2016, 03:23 AM   #10
jr1966
Same problem here.
Do the upper spring retaining bolts have a welded nut inside of the frame ?
If so how do I get the rest of the bolt out after cutting the head off ?
jr1966 is offline   Reply With Quote
Old 11-01-2016, 05:07 AM   #11
cruisinthe34
jr 1966
I didn't have to cut the bolt head. I ended up actually cutting the coil springs up near the top so I could get a socket\breaker bar on the lower nut and a box end wrench up on top of the frame. Mine were NOT welded to the frame rails.
Now that I think about it, after cutting the coils, I had a box end wrench on top and my impact wrench on the bottom. No problem removing then. on Install, it was a boxend wrench and a rachet.
Steve
Old 11-01-2016, 09:06 AM   #12
jr1966
Thanks a bunch . I will get out the cutter and get coil cut first.
JR
Old 11-01-2016, 08:01 PM   #13
rocknss
rocknss's Avatar
On my Burb it had bolts and nuts that held the coils on, which I had to cut to remove them. PB Baster and Heat did not work.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Thread Tools
Display Modes
