15x11
I have a 69 chevy truck with the standard width rearend.... I need to know what backspacing would work and look best... inside wheel tubs wont be an issue...and I'm going to be lowering the rear of the truck either 5 or 6"....
wanting to run a set of weld s76 17x6" up front and a 15x11 beadlock out back
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Re: 15x11
and what backspacing for the front lowered 4"..
Re: 15x11
I have a 69 CST10 396. I also have the original 12 bolt 6 lug rear end. I always had trouble hooking up even with 10 inch slicks. When the tree went green, the back tires would loose traction and smoke off the line. Very frustrating. I needed more meat back there. I took two of the 15x8 factory steel rally wheels with 4 inch back spacing and had them widen to 12 inch with a 7 inch back spacing. Now I can use a 15 inch slick. I didn't narrow the rear or modify the frame. I cut my wheel tubs in half and cut my bed in towards the frame. The wheels fit over the drums and cleared every thing with room to spare. I originally wanted to widen my wheels to 14 inch's and use a 8 inch back space. Someone talked me out of it saying I would have clearance problems. He was so wrong. I mounted the 12 inch wide wheels and tires and had lots of room for my idea. I'm still going to have two more wheels widen to 14 inch's as I original planed. With the 10 inch slick, the inside sidewall of the tire would rub the side of the wheel tub around a corner. So there really isn't much room for big tires back there unless you do some modifications.
Re: 15x11
Thanks.. I have already modified the wheel tubs and bed... I used to run a Hoosier qtpros that had a 12 tread and it worked great...but can't remember what bs I had on those rims...
Thread Tools | |
Display Modes | |
