Old 09-18-2016, 09:52 PM   #1
1971c10La
Drum to Disc brake swap
Can I take the disc brakes off a 1971 c10 5lug and put it on a 1970 c10 6lug would I just need 6lug rotors what all has to be took off to work
1971c10La is offline   Reply With Quote
Old 09-19-2016, 01:04 AM   #2
custom10nut
custom10nut's Avatar
Re: Drum to Disc brake swap
No, the spindles are different sizes
custom10nut is offline   Reply With Quote
Old 09-19-2016, 07:53 AM   #3
Mrturner1
There are some very reasonably priced disk brake kits that have all the pets you need. I think I found a 6 lug front disk conversion kit for about 500 bucks or so
Mrturner1 is offline   Reply With Quote
Old 09-19-2016, 08:03 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
The aftermarket 6-lug rotors that all the brake compamies sell will bolt directly on to a set of oem 71-72 spindles.
BUT,... the spindles will not bolt on to your 1970 truck suspension without changing the balljoints and outer tie rods.
An easier solution would be to use aftermarket 6-lug rotors on 63-70 conversion spindles.
These spindles WILL bolt directly onto your 1970 truck suspension.
Keith
Convert to disc brakes.
Thread Tools
Display Modes
