Old 09-20-2016, 02:18 PM   #1
cjoenny89
cjoenny89's Avatar
LMC shoulder strap seat belt installation
Has anyone installed the LMC shoulder strap seat belt kits? I would like to know if anyone has done it with out drilling any extra holes in the floor? The installation instructions are terrible! we replaced the old lap belts and I can not for the life of me figure out how to get the bottoms installed with out drilling an extra hole in the cab. if anyone has pictures of what they did I would appreciate it very much!
cjoenny89 is offline   Reply With Quote
Old 09-20-2016, 09:17 PM   #2
everettelane
everettelane's Avatar
Re: LMC shoulder strap seat belt installation
I have purchased the shoulder straps from LMC also haven't installed yet but curious since you brought it up.
everettelane is offline   Reply With Quote
Old 09-20-2016, 09:19 PM   #3
davepl
davepl's Avatar
You need an extra hole, no way around it. I opted to drill mine through the seat brace in the floor, since it is heavily reinforced, and used large washers so it wouldn't pull through.
There are multiple threads on this already... I searched and found the one with photos and so here:
http://67-72chevytrucks.com/vboard/s...ill+hole+brace
I'm not an expert, not an engineer, and I doubt this would pass DOT regs.... emulate at your own risk!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-21-2016, 03:00 PM   #4
sangell
I have a set also that I have yet to install but does the anchor side of the lap belt not attach to the same hole/bolt at the top of the "L" bracket that the retractor uses?
sangell is offline   Reply With Quote
Old 09-21-2016, 03:34 PM   #5
cjoenny89
cjoenny89's Avatar
If you can get it to work send me pics
Old 09-21-2016, 03:38 PM   #6
sangell
Well this doesn't instill much confidence, at least I know now going it there will be an issue. I'll look into in and let you know.
Old 09-21-2016, 06:01 PM   #7
cjoenny89
cjoenny89's Avatar
I am about ready to look at it all again!
Old 09-21-2016, 09:43 PM   #8
ripper70
ripper70's Avatar
I just got done with mine and getting ready to post on my build thread..here is a pic. I did use the L bracket and bent it a little bit.
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 09-21-2016, 09:45 PM   #9
ripper70
ripper70's Avatar
well the 1 on the right is crap pic. Should of looked at it but 1st one should be all you need.
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
Old 09-22-2016, 06:12 AM   #10
cjoenny89
cjoenny89's Avatar
The first pic is of the passenger side? How did the driver side go with the gas tank right in the way?
Old 09-22-2016, 03:08 PM   #11
ripper70
ripper70's Avatar
I do not have a factory tank so that could be an issue
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
Old 09-22-2016, 04:26 PM   #12
cjoenny89
cjoenny89's Avatar
If you don't have the tank behind the seat it is going to help big time on the drivers side
Old 09-22-2016, 04:49 PM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
On mine, I didn't get them from LMC. I used the factory seat belt retractor bolt hole. I added a 90* bracket that was included in my kit. I placed it under my retractor and secured it with a grade 12 frame bolt and then added another nut to the bottom side. I attached the other part of the shoulder belt to the 90* bracket. I might change it because I need some more room in the seat belt. My seat sets up pretty high so with the seat belt on, you don't have much room to move forward and it is annoying.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-23-2020, 06:59 PM   #14
Corts60
Just here to tinker
Corts60's Avatar
Any update on this? Is this the right way to do it?
Thanks!
Old 07-24-2020, 09:52 AM   #15
dz1087
I took a high speed step bit and bored out the existing seat belt hole in the floor large enough to put the bolt that came with the kit through it. Worked well. I drilled entirely new holes for the receptacle side.
One thing I don't like about it is that with the seat back all the way, the receptacle is a little long and as such, the lap portion rides a little high. Makes me suspect that submarining would be an issue in a crash, negating the benefits of the shoulder belt. I also don't like how slowly you have to pull out the belt to prevent the mechanism from catching and locking up.
dz1087 is offline   Reply With Quote
Thread Tools
Display Modes
