Old 10-03-2016, 11:51 PM   #1
c10 custom
6 inch static drop anyone ?
Hi everybody i was wanting to know if anyone has a 1967-72 chev truck with a 6 inch static drop in the front ?
c10 custom is offline   Reply With Quote
Old 10-04-2016, 08:40 AM   #2
scrappydoo2k2
scrappydoo2k2's Avatar
Re: 6 inch static drop anyone ?
Wow, a 6" front static drop would likely require a front dropmember. I think 5" is as low as most have been able to go and maintain a semblance of drivability. A member here, Lolife, can opine more on this subject.
scrappydoo2k2 is offline   Reply With Quote
Old 10-04-2016, 10:52 AM   #3
WarMonger
WarMonger's Avatar
I think I have only seen that low in the front with the help of Porterbuilt?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 10-04-2016, 11:02 AM   #4
plastercracker
i have 3 inch drop springs and 2 1/2 inch cpp drop spindles in front and 6 inch drop springs in rear. and adjustable track bar. it rides real nice and took alignment no problem.
plastercracker is offline   Reply With Quote
Old 10-04-2016, 11:13 AM   #5
hardwaycooke
hardwaycooke's Avatar
I had 5 3/4 and the a arms were 1/2 can off ground. Had to be really careful....put in new engine and went back up to 4 1/2 and much happier
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 10-04-2016, 12:07 PM   #6
Fatherof3
Fatherof3's Avatar
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 10-04-2016, 02:37 PM   #7
AnotherWs6
AnotherWs6's Avatar
What does dropping just the last foot of the frame up front accomplish?
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 10-04-2016, 02:53 PM   #8
n33k0
My guess would be to keep the bumper mounting location where it would normally be on a stock frame. I don't know much about drop members, but I do know that's some wicked modification to the frame!
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 10-04-2016, 02:53 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
It leaves the core support where it belongs so the front sheetmetal will still bolt up/line up to the cab.
fwiw, I originally had a 5.5" drop (3" CPP spring/2.5" CPP spindle & a big block chevy) on the front of my truck and the x-member/lower A-arms were very close to the ground. I ended up raising the front up almost an inch with some 2" Hotchkis springs.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-04-2016, 03:06 PM   #10
AnotherWs6
AnotherWs6's Avatar
It's essentially dropping the core support, correct? So wouldnt the front end sheet metal then be off compared to the cab sheet metal?
I get the concept of getting the body down rather than the suspension, thus keeping your control arms off of the ground. Just not getting how it ends up working.
Old 10-04-2016, 03:10 PM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
Negative, he's raising up the front cross member only (and the suspension bolted to it) in relation to the rest of the truck (see pic 1 & 2). The core support and framerails under the cab & bed keep the same relationship.
Adam
Old 10-04-2016, 03:18 PM   #12
AnotherWs6
AnotherWs6's Avatar
Ahhhhhhhhhh, I see. He's cutting both ends. Now that makes sense to me.
Old 10-04-2016, 04:17 PM   #13
Fatherof3
Fatherof3's Avatar
The pictures aren't mine, sorry I didn't add an explanation.
Z'ing the frame used to be more popular before air bags and after market crossmembers.
Lots of fabrication but done right makes for a nice driving low truck with reasonable clearance.
Old 10-05-2016, 09:36 AM   #14
AnotherWs6
AnotherWs6's Avatar
Cool. But that basically shoves everything higher in the engine bay, right? Things must get pretty cramped.
Old 10-05-2016, 10:22 AM   #15
Fatherof3
Fatherof3's Avatar
Yes, plenty of room in the engine bay
Thread Tools
Display Modes
