Old 10-06-2016, 11:04 PM   #1
jescates
jescates's Avatar
6 lug wheel question???
Will newer 6 lug Chevy wheels fit a 1970 6 lug? I have late 70's rally wheels on now and plan on taking them off to get powder coated, but in the meantime, I still want to drive my truck! I see on Craigslist used 6 lug Chevy wheels and tires pretty cheap, so just wondering if they would work!
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline   Reply With Quote
Old 10-07-2016, 09:31 AM   #2
geezer#99
geezer#99's Avatar
Re: 6 lug wheel question???
While the bolt pattern is the same, the hub center bore varies as does the wheel offset (backspacing).
Look here to compare.
http://www.roadkillcustoms.com/hot-r...#axzz3sTJC7aS5
Old 10-07-2016, 12:02 PM   #3
jescates
jescates's Avatar
Thanks Geezer! That is what I needed to know. Looks like any 6 lug up to 1987 will work!
1970 C-10 LWB
2009 Honda VTX 1300
2013 Buick Enclave
Old 10-07-2016, 03:54 PM   #4
Boatracer
I used 1" billet spacers in the rear, otherwise factory '15 wheels and tires all around. I can't fit the front center cap without a spacer, I'm still working on a solution for that.
'70 C10 SWB
'66 SS Chevelle
'65 Malibu SS Pro Street
Boatracer is offline   Reply With Quote
Old 10-07-2016, 04:32 PM   #5
Mike C
Mike C's Avatar
1/2 ton 4x4 rims on Blazers and Suburbans through '91 will work in addition to the up to '87 on 1/2 ton 4x4 trucks, blazers and subs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-07-2016, 04:48 PM   #6
michael bustamante
michael bustamante's Avatar
6 lug wheels from trucks 99 and up have a smaller diameter hub so they will not slide on.
any 6 lug nissan toyota or chevy wheels should work.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-07-2016, 05:02 PM   #7
demian5
demian5's Avatar
Along with not having the correct center hole bore for front drum trucks and rear axles, the offset is different on the inside and will push the wheels really far inwards and possibly rub the bed or front suspension when turning.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-07-2016, 06:36 PM   #8
jescates
jescates's Avatar
Thanks guys! I found another set Truck Rally's on Craigslist today! He was asking 400, but I offered 200 and he accepted! One of my Hubs was broken, and the beauty rings are better than mine, so it's a win in my book!
1970 C-10 LWB
2009 Honda VTX 1300
2013 Buick Enclave
Thread Tools
Display Modes
