Old 10-16-2016, 09:24 AM   #1
bpmack16
Lq4/lq9 engine question
Somewhere I read you must use a 2003 and up ls engine because of some differences with mounting points with the bell housing or somethkng. I can't seam to find the article soon ask you this. Is there a year range I should stay away for when it comes to an lq4 or lq9 swap? Thanks guys.
bpmack16 is offline   Reply With Quote
Old 10-16-2016, 09:53 AM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Lq4/lq9 engine question
99-00 6.0 have an extended crankshaft so mixing and matching trans is problematic, But if you use all of the factory stuff its good to go. And they have less desirable cylinder heads.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 10-16-2016, 11:21 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
They all will bolt up. GM only uses 1 bolt pattern on ALL LS motors with the exception of the LS4, which is tranversly mounted.
The 99-2000 have the built in crank spacer, which is fine if your using a 4l80e.
The 99-2000 also have iron heads, which work, but are the least "performance oriented" heads that exist for the engines.
There are also some wiring harness differences on the 99-01 engines if you source them from an HD/fleet truck vs a regular donor.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-17-2016, 12:48 PM   #4
tlmoore2501
Brew can you explain some of the differences in harness?I may have an odd ball so I would like to know how to identify what I have.Thank
tlmoore2501 is offline   Reply With Quote
Old 10-17-2016, 03:05 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The engines out of medium duty trucks had different emissions control stuff and longer wiring runs. Some also have a ton of extra body-side wiring that the regular trucks wouldn't have.
Thread Tools
Display Modes
