Old 10-21-2016, 12:36 PM   #1
of13swc
Inside cab coating question??
OK so I have welded up the fire wall and floor. Now my question what should be used to inside the cab for the floor and firewall??
of13swc is offline   Reply With Quote
Old 10-21-2016, 12:56 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Inside cab coating question??
epoxy primer is a good start. I used Duplo truck bed liner on top of the epoxy primer and that is as far as I have gotten so far. I will be insulating soon. It really needs insulation as it gets hot in the cab from engine heat.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-21-2016, 12:58 PM   #3
of13swc
Have you heard of second skin spectrum?
Old 10-21-2016, 01:29 PM   #4
Vinceg
Vinceg's Avatar
I'm in the same spot as Chevy Fleetside. Epoxy primed then endura bed liner on the bottom and top sides. Haven't decided on which way to go with insulation yet.
Vinceg is offline   Reply With Quote
Old 10-21-2016, 02:36 PM   #5
of13swc
How did you apply the bed liner?
Old 10-21-2016, 04:47 PM   #6
Chevy Fleetside
You can roll it on if you don't have a sprayer. It is very toxic and you need a lot of ventilation when applying it.
Old 10-21-2016, 05:11 PM   #7
forestb
forestb's Avatar
why bed liner if you are going to install insulation?
forestb is offline   Reply With Quote
Old 10-21-2016, 05:38 PM   #8
Chevy Fleetside
No reason really. Just extra protection. epoxy primer is probably enough.
Old 10-22-2016, 12:25 AM   #9
Vinceg
Vinceg's Avatar
X2 on the bed liner. Also hope it adds to the sound deadening a bit.
Thread Tools
Display Modes
