Old 10-29-2016, 01:18 PM   #1
Chris1salazar
72 C10 w/350
I had a leaking mechanical fuel pump replaced it with an AC Delco and once I run the truck, not even 3 minutes running it shuts down. Two pumps in and it keeps breaking the internals on the pump. The pump levers have no tension when I take them out after the replacement.
Chris1salazar is offline   Reply With Quote
Old 10-29-2016, 03:01 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 72 C10 w/350
Are you sure you've got the pump lever positioned on the push rod correctly?
Tyler
57taskforce is offline   Reply With Quote
Old 10-29-2016, 05:32 PM   #3
custom10nut
custom10nut's Avatar
Re: 72 C10 w/350
Ditto
custom10nut is offline   Reply With Quote
Old 10-29-2016, 08:32 PM   #4
Chris1salazar
Old 10-29-2016, 08:36 PM   #5
Chris1salazar
yes. I removed the bolt also used a flat screwdriver to hold the rod up while I installed the pump and then removed the screw driver, put back in the bolt and it did start and run for a few minutes both times I replaced the pump. Then all of a sudden it cuts off and I remove the pump and the lever is dead and I'm able to move it up and down like nothin....
I'm lost guys....
Old 10-29-2016, 10:05 PM   #6
geezer#99
geezer#99's Avatar
Re: 72 C10 w/350
Leave the bolt out!
Old 10-29-2016, 10:09 PM   #7
Chris1salazar
Question about leaving the bolt out. Will it leak oil?
Old 10-29-2016, 10:18 PM   #8
geezer#99
geezer#99's Avatar
Re: 72 C10 w/350
Maybe!!
My last sbc didn't.
Easy test to leave it out.
If it cures your problem and you're worried about it leaking, just shorten it a 1/2 inch.
Old 10-29-2016, 11:32 PM   #9
Chris1salazar
Originally Posted by geezer#99 View Post
Maybe!!
My last sbc didn't.
Old 10-29-2016, 11:37 PM   #10
Chris1salazar
ill try that in a few days and see what happens. Thanks for the advice. But in the back of my mind I'm thinking why didn't I have this problem with the original on ?
All that happened with the original was it was leaking fuel .
I guys I like to know what causes problem and not just being a parts changer..
I'll keep you posted on what the results are
Old 11-01-2016, 12:42 PM   #11
Chris1salazar
UPDATE:::::
I ordered a new pump from Autozone and yes I know they always seem to screw up but for the first time they did me righteous. $23 and I used the same procedure to install the new one and that sucker went in like butter. 30 minutes and she turned over in no time. Left it running for 30 minutes and damn she sounds good.. now to take it for a drive....
Thread Tools
Display Modes
