Old 10-29-2016, 02:19 PM   #1
ebernst
I guess you would call my farm truck a sleeper. 400+hp, modern suspension, 4 discs...
Here's the build thread so far. She's not done yet!
Here's my 1953 Chevy 3100 Build Thread and here's my website Classic Nation.
ebernst is offline   Reply With Quote
Old 10-29-2016, 04:35 PM   #2
mr48chev
mr48chev's Avatar
Re: I guess you would call my farm truck a sleeper. 400+hp, modern suspension, 4 disc
I'm saving that photo to show idiots that think rust is "patina" There is genuine patina. faded chalky old paint that a bit of CLR and a bit of rubbing compound and polish will bring back to a soft glow with no real rust of defects showing.
Sounds like a fun truck to drive.
My ongoing truck projects:
Old 10-29-2016, 04:54 PM   #3
69chevytrucker
69chevytrucker's Avatar
i think you should keep comments like that to yourself.
this is a truck forum for all types of truck people some like lowered some like jacked some like $30,000 paint jobs some don't. i am not a authority figure on this site but when your wrong you are wrong.
69chevytrucker is offline   Reply With Quote
Old 10-29-2016, 05:15 PM   #4
xaircav
xaircav's Avatar
ebernst, What is your wheel and tire size? What you have looks great. I want to get way from my current big and little look to equal all around ( I'm thinking 235/75-15). This will fill the wheel wells and allow me to rotate tries as needed.
xaircav is offline   Reply With Quote
Old 10-29-2016, 08:27 PM   #5
BIGglaSS
BIGglaSS's Avatar
...don't be sleepin' at the light if this thing pulls up beside you! Great looking truck. More details?
BIGglaSS is offline   Reply With Quote
Old 10-29-2016, 08:44 PM   #6
TogglesSA
TogglesSA's Avatar
Hi,
Very nice truck, I've checked out your build thread on Project Racal. Would you be willing to share some info on how you got the LS in there ? (what you did and what you would have changed?) It looks super tight between the rails. would like to know the height from top of frame rails to center of crank pulley if you willing to share :P. and what steering box configuration you ran to get past the headers.
Togs.
TogglesSA is offline   Reply With Quote
Old 10-29-2016, 09:20 PM   #7
xaircav
xaircav's Avatar
You guys know I meant tires not tries. I like the Impala in the background too.
Old 10-30-2016, 12:11 AM   #8
ebernst
@xaircav Wheels are 15 x 7 GM wheels that I tack welded on some hubcap clips on so that I can run stock style hubcaps. Tires are Coker Classics 2 3/4 Inch Whitewall - 225/75R15 all the way around.
@BIGglaSS Check out my build thread for all the details and more pics!
@TogglesSA It was definitely a tight squeeze getting the LS to fit with those headers. I had to trim back the frame rails a bit to get it to work (but then boxed the rails in to add strength) I'm actually working on the next post in the build thread which will have some photos of the fitment issues and solutions. I haven't measured that frame top to center of crank, but I have some photos that should give a better idea of what is going on. Steering is a power rack & pinion setup with the linkage routed just outside the headers (see last photo).
Old 10-30-2016, 12:25 AM   #9
TogglesSA
TogglesSA's Avatar
Haha, that tight chassis/headers cleareance are just begging to run the headers straight up into 2 turbo's... :P Very nice job so far. Please keep posting so I can copy you :P
Togs
Old 10-30-2016, 12:31 AM   #10
ebernst
Ha, believe me I thought about it.
Old 10-30-2016, 08:56 AM   #11
Katrina/10
Katrina/10's Avatar
I bought an IFS from Scott's also, but it came with a c-notch for the rack. I did not use that, I installed the crossmember so that the rack went under the frame without cutting, as you did. Did you specify that yours be made that way?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 10-30-2016, 01:27 PM   #12
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I like it man, truck looks great.
--Josh
Old 10-30-2016, 01:29 PM   #13
ebernst
@Katrina/10 - I didn't really specify "no C notch for the rack", but Justin asked me if the plan was to build the truck to lay frame, and if I was going to C notch the rear end. I told him it wasn't, and that I didn't even need drop spindles, so I suspect he figured I wouldn't need it for up front either. I'm really happy with the stance. I think it's about a 4" drop all the way around, so it isn't too extreme but looks really good, in my opinion.
Old 10-30-2016, 02:10 PM   #14
dsraven
hey ebernst, nice work and fast. just curious, by the pics it looks like the headers run very close to the steering shaft u joints. is that just a pic thing or are they that really close? just asking because you may have clearance issues when engine torques up, that would mean your steering jams against the headers. also, the ujoints will cook over time. not being critical, just asking.
Old 10-30-2016, 04:34 PM   #15
mr48chev
mr48chev's Avatar
I'm liking that truck better all the time now that I see the work you did on the chassis. That should be one good running good driving truck when you get it all squared away.
Old 10-30-2016, 05:43 PM   #16
ebernst
@dsraven Yeah, I thought about that a bit. I think I should be ok because they are heat treated ceramic coated headers, so they won't run as hot as some other headers. And, I've got the engine mounted on poly bushings, not rubber, so movement should be minimal. I'll keep a close eye on it thought and adjust if necessary.
@mr48chev Thanks! I really appreciate it!
Old 10-30-2016, 05:43 PM   #17
Jesse Z
Wow, that thing is perfect. Looks like a genuine old truck, a concept that many "patina" trucks miss completely.
Jesse Z is offline   Reply With Quote
Old 10-30-2016, 07:24 PM   #18
ebernst
Thanks guys! I put on my caps and beauty rings and shot this short vid this morning.
Thread Tools
Display Modes
