Old 10-30-2016, 11:24 AM   #1
12secondnova
12secondnova's Avatar
Manual 205 t-case to 700r4?
So my brother is in the process of building his 72 1/2 ton 4x4 that came factory with a manual. He wants to put a 700r4 in it if possible. All of the 700r4 to 205 swaps ive seen involve using a t-case that had a turbo 350 already bolted to it. Will the 205 off his manual work? Thanks, Chris
12secondnova is offline   Reply With Quote
Old 10-30-2016, 12:01 PM   #2
B. W.
B. W.'s Avatar
Re: Manual 205 t-case to 700r4?
Someone with more knowledge may chime in, but I don't think make a make an adapter to go straight from a 700 to a manual (10 spline) 205.
you will need to change the output shaft on the 700 & the input shaft on the 205. in addition, you will need the adapter housing from a donor TH350/205 combo. Advance Adapters has kit for swapping out the TH350 with a 700. They also have the other hard parts & a lot of tech info. Check Offroad Design also.
B. W. is offline   Reply With Quote
Old 10-30-2016, 03:25 PM   #3
12secondnova
Thanks for the info. Would it be better to just find a 700r4 with a t-case on it all done and sell the sm46 and 205 to fund it?
Old 10-30-2016, 05:36 PM   #4
B. W.
B. W.'s Avatar
I really like the 205, if it were me I'd probably stick with it.
Old 10-31-2016, 09:50 AM   #5
Advance Adapters makes what you need. It requires going into the transmission, so you end up with a fresh transmission. You can move the mount towers forward to the 6-cyl position and the longer trans fit right between. That way no driveshaft work required. There's plenty of room up front and it gets the distributor out of the firewall.
Thread Tools
Display Modes
