Old 11-02-2016, 03:08 AM   #1
s0dajack
Speedo drive and driven gear question
Hi all, I've tried to figure this out but can't seem to get to a good answer. I have a 72 k5 with what looks like a 6" lift on 35" tires. I'm trying to replace both the drive and driven gears. Can anyone recommend a combo of the model numbers I should get?
Wheel:
35 x 12.5 x r15lt
Bf Goodrich all terrain
s0dajack is offline   Reply With Quote
Old 11-02-2016, 09:42 PM   #2
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Re: Speedo drive and driven gear question
If you have the stock 205 transfer case, you don't have any options on new replacement parts. Used ones are also hard to come by. If what you have is still in decent shape, all you need is a ratio adapter. https://transmissioncenter.net/shop/...ratio-adapter/
If you call them they will tell you which one you need based on some info you provide.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 11-02-2016, 10:19 PM   #3
Blazerowner
Blazerowner's Avatar
You can also get an electric speedo that can be set up manually and not have to worry about the gears in the sender. This is the route I went. Not as cheap as a gear but it's nice to have if you ever change anything.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Thread Tools
Display Modes
