New Member
![]() Join Date: Sep 2016
Cost to Lower
New to this, 81 C10 Stepside, Have 4.5 and 6 inch McGaughey Lowering Kit, What am I looking at to install cost wise ? C section , Spindles and shocks.
![]() Last edited by cavedog309; 11-02-2016 at 06:09 PM. Reason: Additional info |
Re: Cost to Lower
Do it yourself......... all bolt on stuff except for the C Notch which is easy if you have a grinder and cutoff wheels.......... I just did mine and never done it before and it was pretty easy if you know you're way around tools.
RIZ |
Diggin The SquareLife
Re: Cost to Lower
Yea man do it yourself its not hard at all did mine in a weekend.....btw what is all in your kit?
New Member
Re: Cost to Lower
We are doing this ourselves, My question was due to our helper which is my Brother has a Shop with 6 lifts so we have plenty of work area but I asked the question basically to get an idea of what one would pay to do this work ! And I guess it would be hourly. McGaugheys kit is straight forward and Brother has done several previously so it should go smoothly its a Chevrolet for Goodness sakes ! Thanks for Your response everybody !
New Member
Re: Cost to Lower
To BBBc10, My kit was purchased from Summit and I got the 2.5 spindles and springs, Flip kit and C Sections plus all 4 Shocks. We are going to put the HD Front Disc Rotors and upgrade to Power brakes also. Should be a Hoot when its done the Truck has a 350/350 with and aftermarket cam and Edelbrock Carb and Performer Manifold. It runs very well with a bit of an oil leak at the back of the Intake, No biggie there though. I want to have the Trans rebuilt for a bit of 1/8 mile fun at the local track. Should be a Hoot !
Cruzzzn' Vet
Re: Cost to Lower
Back in 83 when I had my new 83 Silverado lowered it was $300. bones out the door,, flip kit, 2 cut coils, alignment kit and shocks. Work done by Cal Truck Works out of LA. Back then $300 wasn't cheap!
Re: Cost to Lower
Ah ok glad you got the spindles an springs up front instead of the control arms.....but a heads up keep a eye out on the flip kit seen many ppl have problems with it also the front springs been giving ppl problems also
New Member
Re: Cost to Lower
Bell Tech was used on Brothers work, Is there issues with this Manufacturers hardware ?
Re: Cost to Lower
We used mcgaughys on my truck and it lowered me way more than advertised on the front. The flip kit seemed ok but I think the u bolts are a little short. I did not use a c-notch, my dad was against it.
1978 Hawaiian Blue GMC 454/Tremec TKO 500 BUILD THREAD |
Re: Cost to Lower
Sorry thought i had read it was a djm kit....many problems wth them....but wth mcgaughys like said above gonna be lower in front.....an i think the notch is not so good......i had western chassis on mine wth belltech flip kit which are 2 higher quality than the other brands
New Member
Re: Cost to Lower
Oh well, We sure are gonna find out. More to come !
Re: Cost to Lower
Slightly off topic....BUT... , cut off the old bump stops, put the the litle mushroom shaped polyurethane bump stops in before cutting the c-notch, and see how it works for you. My truck is flipped with no c notch...its worked out ok.
#13 |
Re: Cost to Lower
When i lowered my truck wth a 6" flip kit an installed the notch i found out u can lower 6" without using a notch if your never gona haul anything or tow
#14 | |
![]() Join Date: Feb 2016
Re: Cost to Lower
I've had a c notch kit sitting under my workbench for two years now. I just haven't seen the need to install it. 5 inch drop front with axle flip in rear and no notch and removed factory bumpstops. ![]() Last edited by Shady Rascal; 11-07-2016 at 08:19 AM. |
#15 |
Re: Cost to Lower
I notched my truck when I flipped the axle, and while I ~certainly~ carry loads (1000+lbs) in it, the pumpkin hits the bed floor before the axle tubes even hit the un-notched frame.
Don't notch it, and then after a while see if you actually needed to. You can always do it later.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Thread Tools | |
Display Modes | |
