11-02-2016, 06:17 PM | #1 |
PROJECT 7DEUCE
door seal top flapper thingie?
Anyone have any good pictures of how this thing should attach?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-03-2016, 12:09 AM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: door seal top flapper thingie?
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
11-03-2016, 12:12 AM | #3 |
11-03-2016, 09:53 AM | #4 |
2WD Jimmy
OK... I havnt seen one of those. Is it for a double wall only?
11-03-2016, 01:43 PM | #5 |
PROJECT 7DEUCE
Both single and double wall tops as far as I know
11-03-2016, 04:39 PM | #6 |
both of mine are broken at the bend and the top is missing... are they important?
'72 K5, known as 'the Fox.' |
11-03-2016, 04:59 PM | #7 |
Not important, just helps defect rain/water from coming into the cab at that corner.
11-04-2016, 09:59 AM | #8 |
Maybe I should get some new ones, because that's exactly where water comes in. And then directly onto my left knee!
11-05-2016, 02:54 PM | #9 |
Anyone know where to get these parts? Also the plastic piece (cap) just below it that mounts to the door itself?
11-05-2016, 04:41 PM | #10 |
PROJECT 7DEUCE
Gmc pauls
11-05-2016, 05:56 PM | #11 |
Yep, you have to have them if you want to keep the water out. And don't forget the RTV - see BobbyK's pics.
11-05-2016, 06:27 PM | #12 |
good pics Bobby, thank you
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Thread Tools | |
Display Modes | |
