Old 10-10-2003, 03:19 PM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
3.08 gears and 20s?
I have a 72 chevy pickup, it has 3.08 gears with posi. I am going to put a 4l60e trans and 20inch wheels on it. Assuming i am going to drive this everyday should i change the gearing to say a 3.73? or ?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 10-10-2003, 03:21 PM   #2
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
That is up to you really... You will get better gas milage with the 3.08's but you will get better acceleration with say, 3.73's. If it was me I would just keep the stock gears in it and drive it as it is..... then again I don't race my truck.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 10-10-2003, 03:21 PM   #3
crazy4chevs
crazy4chevs's Avatar
(3.73) that sounds about right with a 4 speed auto.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 10-10-2003, 03:25 PM   #4
crazy4chevs
I must type slow u beat me to the punch. Most of the newer vehicles ive seen with a 4speed at have had 3.73 or close to it.
Old 10-10-2003, 05:04 PM   #5
bpmcgee
bpmcgee's Avatar
I don't recall if that tranny has an overdrive. Here's my experience with my SM465 (4 speed stick, 1:1 top gear):
I've got a 3.08 posi rear end and stock tires on my 4x4 blazer. I find that in the 70-75 MPH area I'm doing between 2500 and 3k. My feeling is that this is probably near the sweet spot for these 350s. I would say that if your goal is to drive it every day, stick with the 3.08s unless you have an overdrive.
Brian
bpmcgee is offline   Reply With Quote
Old 10-10-2003, 05:10 PM   #6
Josh
He's got mean nasty FANGS!
Josh's Avatar
4L60E is an electronically controlled overdrive (700r4 thats electronic basicly)
Depending on what size tires you run, and what speeds you want to cruise at, a 3.73 would be a great choice.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 10-10-2003, 05:49 PM   #7
Slammed67
Progress = 0%
Slammed67's Avatar
I have 3:08 with a 700R4 (18" wheels/27" tall tires) and it has pretty damn good accelertion. The best of both worlds..... good launches and highway cruisin! It'll chirp the tires when it hit's 2nd gear. Might as well try out the 3:08 first and see if you like it. I think you will
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-10-2003, 07:53 PM   #8
68 Stepside
huh?
68 Stepside's Avatar
I have a 4L60 and 2.56 gears in my roadmaster It has no balls from takeoff, but the 21 MPG average combined city/highway makes up for it
My Z28 had a 700R4 backed by a 3.08 posi. I was more than happy with it, still had good takeoff acceleration, and it would flat out fly. I'm with Jason, stick with the 3.08's for now, you'll probably like it.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-10-2003, 11:12 PM   #9
Chad
Chad's Avatar
My Dad has a 71 SWB with a 350/700R4 setup. It has 3.08 rear gears and gets right around 20 MPG. Not too bad for a huge of steel. Oh yeah, it flys out of the hole too!
Chad
69 Short Fleetside
72 2wd Blazer
70 4x4 Blazer
67 Chevy(big window) Just a cab for now
64 Chevelle SS (2dr Ht)
Chad is offline   Reply With Quote
Old 10-10-2003, 11:19 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
What size 20's are you going to run? The overall diameter means more than the rim size. Your 3.08's with a turbo 350 is a bad combo, but not with a 4L60E. The 4L60E has a much lower first gear than the turbo 350, so it pulls better out of the hole. The overdrive might be a bit much on the top side.
I say get you tires and tranny in, then decide if you need gears. 3.73's are a great gear for low end, but a 3.42 might be the best of both worlds...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-11-2003, 12:31 AM   #11
Richard
As said earlier the tire diameter is what matters. If I am not mistaken the 4L60E has a 1st gear the same as the TH400 which is just about the same as the TH350. The 700R4 has the lower first gear but a bigger gap between 1st and 2nd. IMO the nice thing about OD trannies is the ability to have a much lower rear end ratio for performance and still have good driving characteristics on the freeway. I had bought my 94 with 3.42 gears knowing I was going to run a 285/40/17 in the back (about 26.5" tall) it was perfect. Got tired of the low look and raised back to stock and have a 275/60/17 now, a bit taller than the stock 15" tires (28"-29") It is a dog as far as I am concerned and my milage actually dropped because the motor chugs in OD now. My 72 will have 4.88 or 5.13 gears with the 38" tires and 4L80E tranny, I expect 17-18 mpg with the new motor on the highway. You can check out www.700R4.com for their calculators to give you a better idea.
Richard
Richard is online now   Reply With Quote
Old 10-11-2003, 01:25 AM   #12
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
my K-10 has 3.08's and 31x10.50's, th-350 and a 350.......I hate my gears, this thing is bad doggy and has alot of trouble pulling much of a load.......3.73's are on my wish list.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 10-11-2003, 02:02 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally posted by Richard
As said earlier the tire diameter is what matters. If I am not mistaken the 4L60E has a 1st gear the same as the TH400 which is just about the same as the TH350. The 700R4 has the lower first gear but a bigger gap between 1st and 2nd......
-It looks like we are both wrong. The 350 and 400 have a much lower first gear than the 700r4 or 4L60E, and the 700R4 has a lower second gear.
That is according to Stan Weiss whoever he is...
GM TH-350
2.52:1 first gear, 1.52:1 second gear
GM TH-400
2.48:1 first gear, 1.48:1 second gear.
GM 4L60E
3:08 first gear, 1.88:1 second gear
GM TH-700R4
3.06 first gear, 1.63:1 second gear
Old 10-11-2003, 03:05 AM   #14
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
has anyone put a 4L60E there truck or seen it done? all I've seen is 700r4s. I bought a wrecked 95 fullsize truck and would like to use the tranmission but need more info. By the way I bought the truck for 300 bucks I couldn't pass it up.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 10-11-2003, 03:21 AM   #15
Josh
Josh's Avatar
The 700r4 and the 4L60E are the same tranny, the 4l60E is jsut electronically controlled, where the 700r4 (or the 4L60) is hydraulicly controlled. The gear ratios for the 700r4 should be identical to the 4l60e.
The 1-2 gear split is pretty bad, really noticeable in my caprice w/TBI 305/4l60/2.56:1 rear gears. But behind a mild 350 with the right gears it shouldnt be very noticeable. The low (high numerically) first gear is nice to have, even if it has a slight split between first and second. I assume form your sig you have an Lt1? Or do you have the 4.3 V8?
The RPM calculator at http://ring-pinion.com/calculators/calculatorsind.html should give you an idea of how different gears and tires will affect engine RPMs in various gears and speeds.
JayDubBlazer, you would probably be better off selling the 4L60E and going with a 700r4, it'll be easier and cheaper. To use the 4L60E you'd have to buy an aftermarket computer to control it and would wind up spending more than its worth to run it.
2004 K2500 Burb
1999 C3500
1969 C-10
1967 C-10 Panel
Old 10-11-2003, 03:25 AM   #16
Iron-Butt
454 club
Iron-Butt's Avatar
Thanks for the 700r.com info , Richard.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-11-2003, 06:13 PM   #17
Richard
I will see if I can locate the page I found that has all the GM trannie ratios. As I said before the 700R4 is the lowest. Remember numerically higher is a lower gear, so according to your list the 4L60 is the lowest followed by the 700R, 350 and the 400 highest.
I just found this list http://www.chevellestuff.com/generic/rpm_calculator.htm
It says the 4l60 and 700r are the same as well as the th400 and 4l80e, with the exception of the 4l80 having overdrive. I really dont care for the large jump inbetween 1st and 2nd on the 700 and i guess my 4l60. With lower gears it is not as noticable but the higher the rear ratio that gap becomes more noticable.
I guess I pretty much repeated what Josh said
My brother has a 700R4 from Bowtie in his tpi chevy powered Jeep. Been great. He had it installed by them and I cant say I was impressed by the workmanship that they did on the install. They kind of butched his crossmember and did not reinforce it, the modified exhaust had the tailpipe just fall off and the speedo was not hooked up for the test drive. He had spent quite a bit on the whole install and I expected more. When he inquired about the problems they were very defensive. I believe the difference in a good company and a bad one is how they handle the problems, they did not shine here. As I said the tranny is fine.
Richard
Old 10-11-2003, 10:33 PM   #18
Denny
Denny's Avatar
I have a 4L80E trans in my 69 C-10. It had 3.08 gears aand I changed it over to 3.73 with posi just recently. I was never happy with the performance with the 3.08 gears.
Wes you can use the Compushift computer with the 4L60E trans.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-11-2003, 11:45 PM   #19
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Them boys over at Pheonix took good care of you didn't they?
I'm very lucky that they're local to me. They build every automatic I use.
Old 10-13-2003, 02:39 AM   #20
JayDubBlazer
go cyclones
Denny:
Compushift computer seems pretty neat. How much wire did the system add to your engine bay. I noticed you have to hook up Throttle Position Sensors on your carb. that didn't end up being to finicky did it. I may PM you as I learn more about the system.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 10-13-2003, 03:24 AM   #21
JayDubBlazer
go cyclones
good website
here is a site I found that has a good explaination of compushift and a 4l80E install
http://www.ocmhz.com/33_coupe_trans1.htm
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 10-13-2003, 01:42 PM   #22
/<eystroke
/<eystroke's Avatar
Tire size will be a large factor in this decision.
If you keep the 3.08 rear, you will need a very low rpm stall converter
because you will be idling the engine at 1200rpm while doing 55mph
with 31" (285/50R20) wheels. I doubt you will ever fully lockup the
torque converter before 55mph, which will cause it to slip and generate
more heat which will wear out the fluid sooner.
In my opinion, you will be happier both with the performance and
longevity of the higher 3.73 rear when you get an overdrive
transmission.
Here is a graph of your rpms/speed with 31.2" tires comparing a 3.08 to
a 3.73 rear. Let me know if you want a graph with a different tire
size.
'69 C/10 Short Wide
350/400/AC/Tilt/Tach
/<eystroke is offline   Reply With Quote
Thread Tools
Display Modes
