Old 03-29-2002, 04:20 PM   #1
robby
Semper Fidelis
robby's Avatar
Post get a load of this!
I was happy as a clam with my "free" low mile 307 and after getting it(long block with parts) from a "friend" I put in a new timing chain seals and gaskets, manifold carb etc. well I thought I would save my back and put in the distributor before I poked it in the engine bay today. WELL-I couldn't get the dist. in the last little bit(I have done this a million times) I think my friend gave me a big block dist. driveshaft, so I will tear it back down and put in the correct one. glad I did this before I gave back the cherry picker or I would have been a basket case.
72 C-20 lwb 70 C-10 lwb
69 C-10 lwb
83 Silverado 4X4
Lamar,Missouri
Semper Fidelis
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 03-29-2002, 04:30 PM   #2
bbs1965
Open Sundays 10 till 10
Post
small blocks and big blocks run same distributer.
parts for sale always
30 minutes south of Dallas on I35
WWW.BBSAutoSalvage.com
bbs1969@direcway.com
bbs1965 is offline   Reply With Quote
Old 03-29-2002, 04:35 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Post
I've had same problem. I just bump the engine a little until it falls into place
Jeff Jesseman
Cheyenne Parts Northeast
Franconia, NH
67 Chevy SWB Fleetside
70 GMC Burb 1/2 ton 2wd
72 Chevy Burb 3/4 ton 4x4
Parts bought and sold
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-29-2002, 04:40 PM   #4
69 longhorn
Post
Small blocks & big blocks do run the same dizzy,but the pump drive is different.....If i remember right,by about 1/8". Before you tear it down,you might try slammin the dist in a couple times......the drive shaft may not be seated on the pump.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-29-2002, 05:59 PM   #5
busterwivell
Post
We put the HEI from my daughter' wrecked Malibu 267 in my friend's 454 Dump Truck and he's been running it for 8 years. He'll probably be mad if I tell him it won't work after all.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-29-2002, 07:37 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
Post
They are the same distributer. I told a co-worker that they were the same before he went to the junkyard to get one. When he was there they told him the small block dizzy was $25 and the big blocks were $50. He didn't listen to me and got the $50 one. After that I tried to sell him piston return springs and blinker fluid. Lights are on-nobody was home
Like CPNE said, turn the engine over a touch and it should drop in. If the oil pump rod isn't lined up perfectly it will keep the distributor from dropping in. Get it right and it will drop.
1971 C-10 Suburban
1972 C-10 Suburban
1969 XL Galaxie Fastback
1968 Galaxie 500 Fastback
1974 SCOUT II
Montrose, Minnesota
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 03-30-2002, 01:49 PM   #7
robby
Semper Fidelis
robby's Avatar
Post
Gentlemen, I have figured it out! My friend didn't give me the pump drive shaft, it was from a bigblock I had a long time ago. I got the correct one and the dist. went right in in a snap!
*Yes bigblock dist will interchange
*No oil pump driveshafts will not it has to do with deck height
69 C-10 lwb
83 Silverado 4X4
Lamar,Missouri
Semper Fidelis
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 03-30-2002, 01:50 PM   #8
robby
Semper Fidelis
robby's Avatar
Post
ttt
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 03-30-2002, 04:05 PM   #9
jostrans68
Jostrans68
jostrans68's Avatar
Post
to add to the mix they made tall block big block truck engines
68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar
Tacoma Wa. The Rain capitol of the USA
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Thread Tools
Display Modes
