56 - autocross
Door gap size
Doing a 56 with a very rigid chassis. What would be appropriate door gap measurement? 1/8, 3/16?
Thanks in advance! |
![]() ![]() Join Date: Nov 2008
Re: Door gap size
Not sure it matters as long as it looks good to you AND you make it as consistent as possible from one end to the other....and it ain't easy on these trucks because they never fit all that well from the factory.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Re: Door gap size
i like something around 1/8 to 3/16
Re: Door gap size
I have a 56 and the gapping i have is 3/16, BUT, as already said, as long as it's consistent front and back and up and down, and you're happy, what else matters!! my 2 cents!!
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
Re: Door gap size
lots of guys use a paint stick as a guide to keep all the gaps the same or close. I think a paint stick is 1/8". you can use several on a door when adjusting. leave the hinges sort of loose so the door can be moved with some muscle,install some paint sticks in the gap areas, then tighten the hinge bolts. it may work, doesn't always. it is nice to have a friend help who can be the inside guy on the wrenches or the outside guy with the sticks. sometimes leaving the door latch off can help as well because the door isn't being forced up, down or inward. like said above, as long as they are consistent and you like it, then all is good. don't get hung up on what everybody else thinks, it's your truck, do what you like. that is what hotrodding is all about. oh yeah, make sure the door seals actually seal after as well.
Re: Door gap size
1/8 gaps means you will be doing a lot of touch up painting
truk has a fully boxed chassis and a substantial welded in x-member but still flexes considerably
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: Door gap size
you could also make your own gap tools from a stick of wood or a piece of plastic. plastic shops usually have some scraps laying around that they give away or sell cheap. no marring that way and they don't usually compress like wood does.
Re: Door gap size
good thinking ogre. the door hinges are also not exactly precision. my new hinges allow the door to sag a bit when the it opens.
#9 | |
Re: Door gap size
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
56 - autocross
Re: Door gap size
Re: Door gap size
thanks for the advice martinsr, I will do that when I do the final fit for the door. then pin everything so it goes back the same after dissassembly/paint etc (or at least that is the plan).
#12 | |
Re: Door gap size
The MONUMENTAL job of hanging these parts painted without chipping them is too much a head ache for the tiny bit better finished job. You can tape off door jambs nicely and end up with something barely noticeable. Building the truck should be fun, doing it that way is, painting it apart and hanging all those panels painted, is NOT fun. ![]() Here is a little "Basics of Basics" on the subject. http://www.autobodystore.com/ms27.shtml And another on masking stuff like that. http://www.autobodystore.com/ms24.shtml Brian
#13 |
Re: Door gap size
martinsr, that is what I had planned to do, fit fenders and doors for gaps I can live with, weld on or grind off as required. remove, paint jambs and door interior surfaces and interior of cab, reattach doors to cab and then paint the truck as a unit. less chance of paint blushing etc.
57 gmc fabbing into extended cab. whaddya think? that work? |
#14 |
Re: Door gap size
sorry hotrod1, didn't mean to jack your thread. sorta relevant though I guess.
#15 |
56 - autocross
Re: Door gap size
Its all good. Anything doors is great. These trucks are junk when it comes to fit so all the frustration venting is good. It helps us all understand them a little more. I have spent days adjusting doors and its not good yet.
#16 | |
Re: Door gap size
Brian
#17 |
Re: Door gap size
thanks. it is some 18ga sheet I bent over some stuff I had in the shop to make the curves. built a break on the end of my bench for the bottom bends.lots of fitting involved.
#18 |
Re: Door gap size
check to make sure the doors are not cracked inside around the hinge mounts. mine were off a farm truck and the doors were cracked inside enough so even the piece of metal between the window channels-inside to outside-near the vent window was cracked. the inner skin had seperated around some of the spot welds as well. the door becomes floppy then and is impossible to adjust.
#19 |
56 - autocross
Re: Door gap size
I would sure like to know how you guys drill and pin the hinges on the door and cab side (pictures please). I have spent the last day getting the door straight just to do the gaps. I think all my bolts are starting to gall as the have been in and out so many times.
#20 |
Re: Door gap size
not only use a paint stick along the door gaps, but try using one or two together in the bottom before tightening.
#21 |
Re: Door gap size
3/16 is a minimum, 1/4 is fine
#22 |
56 - autocross
Re: Door gap size
Does anyone have any suggestions on drilling the hinges so they can easily take the door off and have an easy install next time?
#23 |
Re: Door gap size
Once the gaps are set, use an 1/8" drill bit thru hinge to cab, and hinge to door hinge brace. You now have index points at the four variable points. You can do the same for the door jamb latch too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#24 |
56 - autocross
Re: Door gap size
Thread Tools | |
Display Modes | |
