Old 11-28-2016, 07:46 PM   #1
usulnet
1975 Silverado power steering pump
I'm not sure if anyone else has had this problem or not but I have a 1975 Silverado with a 454. On the block is an air compressor, as far as I know it is stock, the options placard shows A/C. Anyhow the bracket for it is fairly oversized. As a result normal power steering pumps cannot fit it without rubbing on that bracket. I've tried two aftermarket pumps, Napa and O'reilly and while both slightly different in appearance they both had fairly large chimneys. My truck has a pretty narrow chimney and I'd just like to find an aftermarket replacement to replace my leaking unit (ruptured exterior so I can't just rebuild). Does anyone still make a replacement that works with that air compressor bracket that we know of? Thanks!
Stephan
usulnet is offline   Reply With Quote
Old 11-29-2016, 11:59 AM   #2
nonstop
Re: 1975 Silverado power steering pump
Might be less headache getting the factory remote reservoir set up, and should have no problems clearing any of the factory accessories.
nonstop is offline   Reply With Quote
Old 11-29-2016, 03:04 PM   #3
kdh454
You can buy the pump without the reservoir if you need to. However, I have a 75, 454 w/AC and my pump looks exactly like what is available below at Rock Auto.
http://www.rockauto.com/en/moreinfo....031971&jsn=426
kdh454 is offline   Reply With Quote
Thread Tools
Display Modes
