Old 12-03-2016, 02:52 PM   #1
sampsmit000
sampsmit000's Avatar
Front Axle question
I have a completely rebilt front axle for my 1964 k10. I have decided I want disk brakes and swapped the front axle out for a 1976 axle. My question is do you think I could sell the axle as a whole or do you think that their would be better just to use what i can from the 1964 axle in my rebuild of my 1976 one?
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline   Reply With Quote
Old 12-04-2016, 01:07 AM   #2
Captainfab
60-66 Nut
Re: Front Axle question
I doubt that you are going to be able to sell a closed knuckle drum brake Dana 44. I would just use the gears and bearings in the '76 housing.
Old 12-04-2016, 01:54 AM   #3
'63GENIII
'63GENIII's Avatar
There was a member here who was able to swap disc brakes onto a closed knuckle axle. It did look like a bit of work but came out super clean. Not the easy route but definitely cool.
Or as Captain said, running the newer housing is the quick and easy deal.
If you do end up getting rid of that closed knuck axle, put it up on the parts board. There are guys out there looking for that stuff for their restorations.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-04-2016, 02:03 PM   #4
61K10
61K10's Avatar
you can use all the 76 parts on your 64 axle. you have to swap all the outer stuff. spindles-hubs/disc/locking hubs. the spindle bearing has to be changed to a bronzed bushing like the 64 spindle or turn your outer axle stubs down a couple of thousands to fit the needle bearing. ck out my build for pics and info.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Thread Tools
Display Modes
