Old 12-09-2016, 12:18 AM   #1
Buffalocouleekid
Buffalocouleekid's Avatar
1967 4x4 power steering conversion question
I am new and this is my first post so bare with me, I have a question on converting a non-power steering 67 frame to power steering. I started out with a bare 67 4x4 frame and 2 parts pickups. I took the axles out of a 87 4x4 chevy pickup and I have the power steering sector from that. I also have a complete 1970 2wd CST/10 that I am robbing the body off of so I can steal the power steering sector from that too. Now from what I understand a 67 4x4 never had power steering. My frame does not have the "bumps" or "dimples" for the bolts for the sector and I am worried about spacing. I am also thinking for some reason that it only has 3 bolt holes instead of the 4 needed, not 100% sure but I will check tomorrow. Anyone have any suggestions? Not afraid to cut and weld as I am also doing a lwb to swb conversion.
1970 C/10 LWB 2wd
1970 CST/10 LWB 2wd (soon to be)SWB 4wd
-Trevor
Buffalocouleekid is offline   Reply With Quote
Old 12-09-2016, 12:23 AM   #2
flashed
Re: 1967 4x4 power steering conversion question
Im in to see what you find out as I have a 67 4x4 shortbed project .
flashed is offline   Reply With Quote
Old 12-09-2016, 12:55 AM   #3
First c10
First c10's Avatar
BCK, welcome aboard!!!
I just did this to my sons truck. Check out my hulk jr build in my signature.
Captainfab (his user name) makes an adapter for the early trucks that don't have the frame dimple for the power steering box. I will try and post a link to the thread.
Good luck and post up some pictures or start a build thread.
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-09-2016, 12:57 AM   #4
First c10
First c10's Avatar
Found it
http://www.67-72chevytrucks.com/vboa...d.php?t=332923
GO GO!!!
Old 12-09-2016, 12:16 PM   #5
Buffalocouleekid
Scott
Thanks for finding me that thread. I wonder if I just drill holes in the correct location and make 1/4 inch spacers to make up for the dimples...
1970 C/10 LWB 2wd
-Trevor
Old 12-09-2016, 01:50 PM   #6
First c10
First c10's Avatar
It's more like 3/8"-1/2" but you need to make sure it is strong as this is a weak point in the frame on these trucks.
GO GO!!!
Old 12-09-2016, 01:56 PM   #7
61K10
61K10's Avatar
you can make your own plate if you have the means to build one. the 2wd box will not work.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-09-2016, 02:52 PM   #8
Buffalocouleekid
Yea I suppose I could build a plate for the inside and use the it as the template for drilling the frame, I am a few steps away currently from this, my frame is currently upside down and I am doing some rust repair on some crossmembers , I should start a build thread once I figured out how to.
1970 C/10 LWB 2wd
-Trevor
Old 12-11-2016, 10:22 AM   #9
trukman1
If I remember right 73-87 trucks came with spacers on the power steering boxes. Since you'll have to use a 4x4 steering box anyway it would make since to get it off the newer "square body" trucks and just use the spacers that come on it as well. Yes, you can drill the extra hole if needed. I've yet to see a three hole 4x4 box but I hear they are out there. I'd stick with the 4-hole unit though.
Seems to me as I look at that adapter plate and the spacers it would be about the same as the spacers I mentioned. As for the weak point, that's true of all the c-channel frames but I've only had one crack after terrible abuse and after welding it I never had it crack again either.
Looks like making a plate with some spacers couldn't be very hard. Just remember to radius the corners. Sharp corners are a "punch point" to the metal they are up against.
Just my opinion.
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 12-11-2016, 05:25 PM   #10
Buffalocouleekid
Just my opinion.
Ha, perfect. I have a 87 box and now that you said that I remember seeing spacers on there.
1970 C/10 LWB 2wd
-Trevor
Old 12-14-2016, 11:59 PM   #11
Buffalocouleekid
just started a thread on this build
http://67-72chevytrucks.com/vboard/s...d.php?t=724854
1970 C/10 LWB 2wd
-Trevor
Old 01-13-2017, 10:01 PM   #12
Buffalocouleekid
anyone know the measurements for drilling the holes and getting the correct angle and placement of these steering boxes?
1970 C/10 LWB 2wd
-Trevor
Old 01-14-2017, 02:15 AM   #13
First c10
First c10's Avatar
BCK. Remember the link I posted. For 60$ it came with the plate, bolts, and a pattern that showed were to drill. It took me a few minutes to install. Sometimes a few bucks can save hours...
Maybe you can ask if anyone can trace you a pattern from a frame with no box installed. Or blow up a picture to match the frame.
Good luck.
GO GO!!!
Old 01-14-2017, 07:08 PM   #14
Buffalocouleekid
Good luck.
You convinced me, I messaged him on buying one.
1970 C/10 LWB 2wd
-Trevor
Old 01-14-2017, 10:17 PM   #15
First c10
First c10's Avatar
keep us posted!!! On the build thread at least!!!
GO GO!!!
Old 02-21-2017, 01:29 PM   #16
Buffalocouleekid
Well I got it and got it drilled and welded on, searched around on the forum to try to get it in the right place, should be able to adjust if I am of a hair off with the alignment. Thanks everyone for the help
1970 C/10 LWB 2wd
-Trevor
Thread Tools
Display Modes
