12-24-2016, 11:06 AM | #1 |
67 c10 with 73 spindles
I know the ball joints will have to be changed in the 67 arms. I know the outer tie rods will need to be changed also. My question is if I get all the steering components from a 73 will it fit my pitman arm. I already have power steering so I'm not looking to change pitman arm.
Living the dream or running it down... Haven't figured out which yet. |
12-25-2016, 10:10 PM | #2 |
Re: 67 c10 with 73 spindles
I take you are from Whitley City KY which is a ways south of Somerset. Been to Somerset and that is a hike from Cincy. Maybe you can gain something from these old threads
http://67-72chevytrucks.com/vboard/s...d.php?t=168486 http://67-72chevytrucks.com/vboard/s...d.php?t=165193
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
12-26-2016, 12:25 AM | #3 | |
12-26-2016, 09:04 PM | #4 |
I still have the 5/8" LH die. Hope it works out, if not PM me.
12-26-2016, 09:10 PM | #5 | |
Much appreciated. I have a decent tap and die set. So I can take a 73 outer and re thread for my purpose from what I read. Sounds easy enough. Might give that a try. I've got a line on a whole crossmember, but I really wasn't looking to pull the engine at the moment.
12-26-2016, 09:26 PM | #6 |
67-72 parts collector,…
You shouldn't have to re-thread anything.
12-26-2016, 09:27 PM | #7 |
Look at the drum to disc conversion thread at the top of the Sudpension Section.
12-26-2016, 10:52 PM | #8 |
I've looked at these threads till I'm blur in the face. That thread is what prompted my question about whether the pitman arm was the same.
Thread Tools | |
Display Modes | |
