Old 12-24-2016, 11:15 PM   #1
Joe Pass
Joe Pass's Avatar
My 56 rear swaybar installation
I purchased a Moser 12 bolt rear end housing to replace my existing stock 68 Camaro 12 bolt after axle tube failure. While I was at it I wanted to add a rear swaybar to the mix. Looking at all the info on this and other sites, I ordered one from Summit for a 68 Camaro. To my surprise it matched up relatively easy and wasn't difficult to install to the stock truck frame. I took pictures as I worked through the process should anyone else want to consider it.
Specs...
My rear suspension consist of a 12 bolt 68 Camaro application. I located the rear end on top of the springs installing 2" wide perches. The stock leaf springs have several leafs removed per side. Ride level is 2.5" to the top of the rearend housing to the bottom of the bed wood. This is as low as I can go without contacting the bottom of the bed or major frame and bed modifications should be considered. I can't tell you if this will work with 4 link or airbagged suspensions...just so you know
Enjoy the pictures
Joe
Joe Pass is offline   Reply With Quote
Old 12-24-2016, 11:18 PM   #2
Joe Pass
Joe Pass's Avatar
Re: My 56 rear swaybar installation
Old 12-24-2016, 11:19 PM   #3
Joe Pass
Joe Pass's Avatar
Old 12-24-2016, 11:22 PM   #4
Joe Pass
Joe Pass's Avatar
With bad weather and the holidays I'm unable test drive but I will update with results...plus this will give me time to tidy up brake lines and look over things..
Until then
Happy Holidays
Joe
Old 12-25-2016, 10:18 AM   #5
blazer2007
did u make those traction bars,if so do you have a write up on them?
blazer2007 is offline   Reply With Quote
Old 12-25-2016, 11:21 AM   #6
Joe Pass
Joe Pass's Avatar
I didn't make them but I boxed the open ends in and painted them. They were available back in the 70's. A close version are these Summit https://www.summitracing.com/parts/l...t/model/camaro
Merry Xmas
Joe
Old 12-25-2016, 04:00 PM   #7
tinydb84
tinydb84's Avatar
Looks great!
David
Instagram: myfabguy
Old 12-25-2016, 05:55 PM   #8
Joe Pass
Joe Pass's Avatar
Originally Posted by tinydb84 View Post
Looks great!
Thanks,,,
Happy Holiday
Joe
Thread Tools
Display Modes
