Old 10-13-2003, 08:24 PM   #1
Chevelle454
Chevelle454's Avatar
Need help with Cam selection, quick!
I am buying a 350 rebuild kit tonight from northernautoparts.com and I need to know which crane cam to go with. I want something that will give me a lot of torque for pulling heavy loads and for good acceleration. I need to make a decision within 2 hours so any repleys would be much appreciated!!! Thanks!!!
-Scott
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 10-13-2003, 08:52 PM   #2
Chevelle454
TTT!
1972 C10
1972 C20
Old 10-13-2003, 08:59 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
I would put an Enegizer 266 in it....good low end cam, and should pull to 4500 rpm pretty good.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-13-2003, 09:08 PM   #4
crazy longhorn
Fabricate till you "puke"
2nd that, the 266 is a good cam for thge money. I have 1 in my plow truck, & have used them in several other apps.....smooth idle, & good tork.........crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-13-2003, 09:10 PM   #5
jamis
F.A.S.T. president
jamis's Avatar
I've used their 460/302 grind in one of my trucks, I used to tow the boat. advance the centerline at 97 to 100 degs for more torque
jamis is offline   Reply With Quote
Thread Tools
Display Modes
