01-11-2017, 10:25 AM | #1 |
Please help me solve this mechanical mystery
I hooked up my overdrive last year on my 700R4. (Did not use the kit, just wired it to activate when I hit 4th gear. (Poor mans solution.) So when I am accelerating and it is about to shift into 4th it does so then 1 second later drops an additional 2-300 RPM's.
I drove it for 3 month and 65 mph was 2100 RPM. Overtime it changed and 65mph became 2500. My idle in park jumped to almost 1500 and it became 1000 in gear. This morning it switched back after many months. 65mph is now 2100 RPM's again and it idles in gear at 700, 1000 in park. What could cause this change? Thank you for the help all. |
01-11-2017, 11:23 AM | #2 |
Re: Please help me solve this mechanical mystery
Check and clean your weights in the distributor.
They can hang up and create higher rpm. |
01-11-2017, 11:51 AM | #3 |
Lockup is the word , not overdrive , might be a bad connection somewhere , or a converter issue , usually if the lockup clutch wears out , it will not start working again , it is possible the something was stuck in you transmission also , Id replace the transmission filter and gasket .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
01-11-2017, 01:19 PM | #4 |
I presume you mean you're locking up the converter? Because there's no wire to control going into overdrive, so far as I'm aware. If that's the case, maybe that unorthodox way of doing things has eventually burned the clutches out of the lockup section?
01-11-2017, 02:21 PM | #5 |
Correct I meant lock-up. I will check it out and thank you!
Thread Tools | |
Display Modes | |
