Old 01-11-2017, 04:22 PM   #1
jgr
72 door
Hey, can all the guts from a 69 door work in a 72 door? I keep hearing the 72 door is different. thank you!!
jgr is offline   Reply With Quote
Old 01-11-2017, 05:34 PM   #2
truckster
truckster's Avatar
Re: 72 door
The 72 door has a screw below the vent window to make it sturdier and the shaft on the regulator is longer to clear the 72 door panel. Other than that they're the same.
truckster is offline   Reply With Quote
Old 01-11-2017, 11:45 PM   #3
jgr
Re: 72 door
Thank you
Old 01-11-2017, 11:51 PM   #4
Rod Run
Rod Run's Avatar
Re: 72 door
doesn't the window crank stick out further also?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 01-12-2017, 10:14 AM   #5
SuperC10Tex
SuperC10Tex's Avatar
Re: 72 door
Yes! If putting 69' crank (guts) in 72' door shell and using 72' door panel, the crank would not stick out far enough.
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 01-12-2017, 01:03 PM   #6
Coley
Coley's Avatar
Re: 72 door
Yep....ditto on the window crank (stud) length.
The '72 inner door panels were thicker/fancier than previous door panels so they had to lengthen the crank pin to stick out far enough.
A lot of guys have got this wrong in swapping doors out and around and have had to find the correct window lift assembly to correct the condition.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 01-12-2017, 01:15 PM   #7
Travisarmenta
Travisarmenta's Avatar
Re: 72 door
Coley
I'm looking at my 71 door, there is def a void between the crank and panel,
would a 72 panel not work on a 71 door?
it seems like there isn't that much difference between the stud lengths
Travisarmenta is offline   Reply With Quote
Old 01-12-2017, 01:17 PM   #8
truckster
truckster's Avatar
Re: 72 door
Yes, the shaft on the regulator is longer, which means it sticks out further.
Old 01-12-2017, 04:02 PM   #9
CUSTOM/10
CUSTOM/10's Avatar
Re: 72 door
Yes you can if your going to use the 69 door panel. If you do you'll need to make provisions to attach the door panel ie: capture nuts or something for the panel attachment screws. ( Then the guts from your 69 door will work )
If you plan to use a 72 door panel then you will need the 72 door opener relay & the 72 window regulator, due to the longer shafts need for the deeper 72 panels..
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-12-2017, 05:10 PM   #10
El Dorado Jim
Re: 72 door
Gary
x2, yes , if you use all of the guts and door panel from your 69
El Dorado Jim is offline   Reply With Quote
Thread Tools
Display Modes
