Old 01-16-2017, 01:20 AM   #1
low1954
Champion 4 core radiator
I have purchased a champion 4 core radiator for my 1972 Chevy k20, and the stock upper radiator mounts don't seem to be fitting correctly. The truck had a 4 core radiator originally. Does anyone know if the upper or lower mounts need to be modified. This is the radiator that is called out for this truck, so just a little puzzled. Any and all help would be awesome. Pictures are also appreciated
low1954 is offline   Reply With Quote
Old 01-21-2017, 05:33 PM   #2
PatrickGMC70
PatrickGMC70's Avatar
Re: Champion 4 core radiator
I hope you get an answer to your question because I'm in almost the same situation.
I'm looking to replace my factory 4-row with either a 3 or 4 row Champion. But I want to make sure it'll fit in my factory mounts without having to build something.
PatrickGMC70 is offline   Reply With Quote
Old 01-21-2017, 05:43 PM   #3
clay68c10
clay68c10's Avatar
The tanks aren't quite the same shape or dimension, so you will have to come up with something. Maybe the 3-row holders can do it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-21-2017, 06:12 PM   #4
72_swb
72_swb's Avatar
Mine didn't fit also. Height was about 3/4" to tall for the factory hold downs. I just bent some plate steel.
72_swb is offline   Reply With Quote
Old 01-22-2017, 02:46 PM   #5
PatrickGMC70
Were you replacing a factory 4-row radiator (with the larger mounts)?
Which replacement radiator were you installing? 4-row? (MC369)
Thanks for any info you can provide. I plan to call them tomorrow, but it would be nice to have some real-world data.
Old 01-22-2017, 03:34 PM   #6
Boog
laying low
Boog's Avatar
The upper and lower rad mounts are different between the 2 - 3 row rads and 4 row rads. You can buy the wider mounts and cushions easy enough. I found even with the correct mounts and cushions mine seemed to sit up too high so I cut the top and bottom cushions thickness in half to lower it just over 1/2" and it fits nice now.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-22-2017, 03:48 PM   #7
leddzepp
Moderator
leddzepp's Avatar
I used the 3 core Champion radiator, it fits very well. Look up the dimensions of all the different core sizes offered, they all vary slightly vary, I believe someone said the 2 core fits "perfectly"
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-22-2017, 04:17 PM   #8
DaHos
DaHos's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=693969
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-22-2017, 06:07 PM   #9
PatrickGMC70
I already have the larger 4-row mounts.
LeddZepp- do you have any cooling problems with the 3-row? If I don't need to stick with a 4-row, I'm ok with a 3 row if it'll get the job done. I was only looking at a 4 row because that's what the truck came with. (It's a factory AC; MT).
Low1954: sorry to ask these questions in your thread. I'm hopeful there's someone who got the 4 row to fit, but it seems like the verdict so far is fabing up new mounting brackets is required for the "direct fit" 4 row.
Old 01-22-2017, 06:12 PM   #10
elf w/capital T
Heavy duty mounts or just fab ones up like a few of us did.... good luck, my 4core champ hasent failed me yet, minus it missing shroud mounting points, i already had it in and on a running truck, didnt wanna take out to give a shop the chance to alumin weld ones on, maybe one day but hey, this truck is all a learning process
elf w/capital T is offline   Reply With Quote
Old 01-22-2017, 06:39 PM   #11
leddzepp
Moderator
leddzepp's Avatar
I have no cooling problems with the three row. I had to add a couple pieces of rubber to the mounts to make them "snug"
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-22-2017, 09:41 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: Champion 4 core radiator
I have bought 2 of the 3 row radiators and haven't had one problem with either one.
The first went in the 71 but I used a custom bent metal piece for the upper hold downs.
The second one I put in the Ramp Rat and used the factory upper mounts. They are not perfect by any means but it holds it fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2017, 08:41 AM   #13
PatrickGMC70
I called Champion yesterday. I was on a quick break at work, so I didn't have a lot of time to get deep in the weeds. They recommended the 3-row to replace my factory 4-row, and advised that the 4 row would likely take up more space than the factory unit. The 3 row should fit with my factory 4 row mounts. They also said that for my application, the 4 row would be less efficient than the 3 row because of the added air resistance of the extra row while using the factory fan.
I ordered it last night. I'll update if there are any fitment/cooling issues.
Thanks to everyone for the help.
Old 01-24-2017, 09:30 AM   #14
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Champion 4 core radiator
Both of mine are the 3 row and haven't had any problems at all keeping them cool. My truck has a 180* thermostat and it will run at 179* all day long. The aluminum radiator it self is good for a few * cooler running I would think. Mine has never gotten over 200 and that was with AC going and driving in the mts on some long up hill grades in over drive and outside was 90*.
Old 01-24-2017, 11:53 AM   #15
1968aj
I am about to order a champion radiator for my 69. there is apackage deal on ebay for $374. it is a 2 row with fans and shroud with wiring harness.i hope the 2 row will cool my 350 with automatic.
1968aj is offline   Reply With Quote
Old 01-24-2017, 12:31 PM   #16
onebigjohn
onebigjohn's Avatar
Why not use this one and not worry?
http://www.ebay.com/itm/1970-85-Chev...xUb8Bd&vxp=mtr
"I pawned my Hanso"
"Hold my beer, Watch this"
onebigjohn is offline   Reply With Quote
Old 01-24-2017, 01:24 PM   #17
davepl
davepl's Avatar
I don't know if mine is a Champion, it's whatever LMC sells as their "house" brand. My truck was an AC big-block so likely already a 4-core.
The mounts still needed some love and hate to work. I don't remember exactly what I did except fight with them 2 years ago... but I did make it work eventually.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Thread Tools
Display Modes
