Old 01-21-2017, 01:18 PM   #1
Ramiro0727
Running alternator wire into cab
I need to run my brown alternator wire into the cab and hook it up to my new wiring harness. I'm thinking of running it on the right side of the right valve cover. Is there anything I can put on the wire to keep it from melting besides wire loom.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 01-21-2017, 07:59 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Running alternator wire into cab
Here's how I ran mine.
I re-clocked the alternator so the plug-in was down.
Name:  My truck engine 008.jpg
Then I ran the brown, red, and large red wires, down by the fuel pump, and across the front cross member.
Name:  My truck engine 007.jpg
Under the radiator.
Name:  My truck engine 006.jpg
To the main junction below the left headlight, and back on the left frame rail to the firewall block, then into the cab.
Name:  My truck engine 005.jpg
I just used the plastic loom you can buy anywhere, and clamped it away from heat or moving parts.
These aren't the finished wiring but they show how I routed the alternator wires.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-22-2017, 12:13 AM   #3
Ramiro0727
Attachment 1613735
Attachment 1613739
Under the radiator.
Attachment 1613736
Attachment 1613737
Thank you VetteVet.
Thread Tools
Display Modes
