Old 01-22-2017, 02:42 PM   #1
dave`12
dave`12's Avatar
Leveling question
My truck (67) sits high in the back. Will 2" blocks in the back level it out? I'm happy with the height in the front. I have the coil rear suspension with the helper leaf. The wheels will be replaced with 20" or smaller (these are 24's).
thanx
dave`12 is offline   Reply With Quote
Old 01-22-2017, 03:22 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Leveling question
Depends on what the measurement is from the ground to the fender lip! Have you measured it yet? If the front is 3" lower than the back, then a 2" block won't do it, and you'll need a drop spring instead. It may only be an inch lower, then you'll just need a 1" block. Time to bust out the tape measure.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-23-2017, 12:13 PM   #3
dave`12
dave`12's Avatar
Ok, I feel stupid. of course.
In my defense, I was away from the vehicle and had heard that from the factory they were 2" higher in the back.
Thread Tools
Display Modes
