LQ4 in to 68
trying to round up all the parts I will need to do the swap. any suggestions/recommendations will be muchly appreciated.
not trying to do things the cheapest way, but not trying to break the bank. just a solid, quality build. I am defiantly wanted to run long tube headers. which one offer the best ground clearance? how is the BRP mount kit work with there headers? is the LH8 oil pan give that much more clearance? is there a direct fit LS swap radiator out there some where? |
#2 | |
![]() Join Date: Apr 2005
Re: LQ4 in to 68
This is what I used: Dirty Dingo slider mounts and CPP engine stands, Cadillac CTSv oil pan, Entropy radiator and Doug Thorley 324 Try-Y headers. You can check out my builds in signature. I would also look through these threads, they will be a good place to start and lots of good information: http://67-72chevytrucks.com/vboard/s...d.php?t=566743 http://67-72chevytrucks.com/vboard/s...d.php?t=456787 If you do a DBW pedal, I also make an adapter bracket for mounting the pedals in a C10: http://67-72chevytrucks.com/vboard/s...d.php?t=651123 Good luck on your swap! I used Dirty Dingo slider mounts and CPP engine stands, Cadillac CTSv oil pan, Entropy radiator and Doug Thorley 324 Try-Y headers.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: LQ4 in to 68
I started here
http://67-72chevytrucks.com/vboard/showthread.php?t=413855 I have not set the motor yet. I want to see how the A/C compressor fits. My plan is move the stock mounting stands back so the compressor will fit. |
Re: LQ4 in to 68
Doug Thorley says those wont work with stock column shift. don't really want to go to floor shifter. trying to get more info on the BRP stuff. anybody used them?
Thread Tools | |
Display Modes | |
