Old 03-08-2017, 07:09 PM   #1
stangtjk
Rear support for body mount
Are these reproduced? I made one but I don't have a brake so it took forever and came out passable but not as nice as I'd like. Would rather just buy it than make another one but not sure what it would be called and haven't seen it in the catalogs.
stangtjk is offline   Reply With Quote
Old 03-09-2017, 01:41 PM   #2
1rippen6
Re: Rear support for body mount
I might have a decent one probably can't check until this weekend.
1rippen6 is offline   Reply With Quote
Old 03-09-2017, 11:50 PM   #3
1rippen6
Mine isn't much better than yours Sorry.
Old 03-10-2017, 12:41 AM   #4
my56chevytruck
my56chevytruck's Avatar
I'm no sheet metal guru like so many others are on this site, but, I've bent steel on my work bench using strong clamps, steel plate over the edge I'm bending and start bending. A good strong hammer helps to. good luck.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 03-10-2017, 02:39 PM   #5
stangtjk
That's pretty much how I made the one in the last picture.... After doing the one I didn't​ want to do another guess I'll just suck it up and start hammering.
Old 03-11-2017, 01:23 PM   #6
stangtjk
Second one came out better and didn't take near as long to make. Guess I was dreading doing it for no reason...
Old 03-12-2017, 10:00 PM   #7
my56chevytruck
that's some good sheet metal work. good job.
1940 Ford Dlx Coupe
1969 Mach1
Old 03-12-2017, 10:09 PM   #8
1rippen6
I think there is a bushing in there also.
Old 03-12-2017, 10:27 PM   #9
stangtjk
Bushing in where? These were practically falling off my tub after I took it off the frame so I could have lost something. It looked to me like they were just welded over the support for the rear body mount and the body mount goes between this and the frame.
Old 03-12-2017, 10:30 PM   #10
1rippen6
It goes into the box you just built I'm guessing it keeps the box from crushing when you tighten it down. I will try and get a picture of the bushing on the one I have.
Old 03-12-2017, 10:39 PM   #11
stangtjk
Oh, yeah there is some metal support structure that the box sets on but it's not a bushing. That piece is still on the truck and was in decent shape. I don't have a close up but in this picture I've got one box installed and the other off. I think that lower piece is what you're referring to.
Old 03-13-2017, 08:45 AM   #12
1rippen6
yea might be I really can't tell from the picture just wanted to make sure you had everything you needed before painting.
Thread Tools
Display Modes
